Question about Philips Magnavox 51MP392H Rear Projection Television
Philips Magnavox 55P8288 . How hard to install kit and change oil
OK, I found out about getting a fix it kit and new oil. Cost about $120.
Thanks for your help in diagnosing the problem.
Question is how hard is it to install the recommended kit and change the oil? Is this a long, detailed process that is likely to get me into more trouble than it is worth. Thanks for the help so far!! Rick
  • rlputnam Apr 22, 2009
    I appreciate the feed back. But I really wanted tp know if it is a time consuming abd problematic problem to fix. I would like to know before I purchase the kit.
  • Philips Master
  • 8,617 Answers
You can get the coolant replacement kit cheaper at the following link and they supply step by step instructions on CD with the Kit. Its 85.00 and indludes shipping to all US addresses.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Posted on Apr 22, 2009
  • Sonny Berry
    Sonny Berry Apr 22, 2009
    Actually its not that difficult to do as the components can all stay on the picture tube with the exception of the Drive board , but its unplug the yokes , and HV lead and remove the 4 screws that attach the tubes to the array and then lift out the tube one at a time. You have to be careful not to bump the alignment rings as that will mess the convergence up. But its actually a very easy proceedure.
The picture is way to orange/red
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Aug 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture on 52 inchtv shows a dark picture
If you go in to the tv menu, you should find picture adjustments. You can adjust the contrast and brightness to fit her preference.
Please give good ratings, it is important to us..
Aug 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX 51MP392
ML
Jul 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox model 51mp6100/37, the power light comes on but no picture or sound. a strange niose comes from the back panel
If its a chirping sound the convergence chips are shorted. I learned this the hard way.
ML
Jul 18, 2009 | Philips Televison & Video
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Same Problem with carloscor Philips Magnavox 55P8288A
the following link has the cd with instructions, or the coolant change kit which has the coolant and cd with instructions on the proceedure. Its listed under the repair kit section.
Jul 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
55p8288 46" Magnovox
in the circuit board labelled "power on"it is a tacking change that switch.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
517 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
