Pro tell me the latest verson of dos and dos command and ho to use it.
    Problem Solver:
The last version of (Microsoft) stand-alone MsDOS was 6.22. The DOS that comes with Windows 98 is MsDOS 7.xx. There are of course, other DOS's, like DrDOS, FreeDOS, etc. etc. What is it you actually need to do?
Posted on Sep 22, 2007
SOURCE:
What's yowhen i try to start the comp. it tells me at the windows boot manager that i have the options to repair but if there is no disk call manufacturer because it tells me that the file ntoskrn
If you can somehow get to a dos prompt (black screen with white writing) then you can fix it without a repair disc or system disc. If not, just borrow a Repair Disc or Operating System Disc from a neighbor, friend, family member or co-worker. Just make sure that the disk is the same as your operating system. Look at your Certificate of Authentication (COA) Sticker that is affixed to you laptop. Most times it is on the bottom or inside the battery compartment. It will tell you which operting system you have and it will have a series of 5 letters and numbers which is your product key. If you have Windows Vista Home Premium, or Windows 7 Home Premium, or Windows XP Professional, then borrow that type of operating system disc or repair disc.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 23, 2012 | Computers & Internet
I cant get laptop to start up!
LOL, when will consumers ever learn to stop being so quick to go out and buy the latest and supposedly greatest operating systems? Windows 7 is so much like Vista with the problems of Startup Repair not working and losing devices, etc.
You reinstalled windows and it still does not work?
Ok, after Startup Repair tells you it cannot repair the problem. Click the option that takes you to the Recovery Menu to see other options. Down at the bottom select the Command Prompt.
When the command prompt window opens (black screen with white writing) they the command:
sfc /scannow then press Enter
When Sfc (System File Checker) finishes run the Check Disk Utility ( I ran one this week on someones computer that was doing the same thing and Check Disk ran for 3 hours, but it fixed the problem).
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 20, 2012 | Dell Latitude D600 Notebook
How to reset a password to toshiba A205-S5804
To enter in to bios, try password Toshiba.
Also:
By UsingMS DOS Command: This methodworks only if you have access to the system when its turned on because thismethod requires MS DOS. Open Command Prompt from Programs menuand provide following commands one bye one: Debug o 70 2E o 71 FF quit NOTE:The first character in the above commands is English alphabet "o"and not the number 0. After providing the above commands, restart your systemand it should reset the CMOS Settings along with the BIOS password. If you arecurious to know how it works? then let me explain the above commands: In this method we are using theDebug tool of MS DOS. The "o" character present atfirst in these commands, outputs the values to IO ports. The number 70and 71 are port numbers which are used to access CMOS memory.By providing FF value we are telling CMOS that there is aninvalid checksum and it resets the CMOS settings as well as BIOS password. By UsingSoftware: There are a few software which canalso reset CMOS settings or BIOS password or both within a few clicks. But asstated above you should have access to a system which is turned on and shouldhave access to MS DOS or MS Windows: CmosPwd . You can download program on this page: http://www.cgsecurity.org/cmospwd-5.0.zip
Mar 05, 2011 | Computers & Internet
For Dos Command
Download a program called Belarc Advisor. There isn't a command that will allow you get the system board number from the DOS prompt without running a 3rd party application.
Jul 11, 2009 | Computers & Internet
Plz tell me how can we install latest verson of software
What type of software you want to install. Check its website to get the latest software.
Jul 08, 2009 | Handmark Software MobileLists (950142) for...
How can I run a dos app without using a command prompt console?
vbscript should be able to do that you can swap between wscript ( which uses the gui ) or cscript ( which uses the command prompt )
May 07, 2009 | Computers & Internet
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Open Questions:
Mozilla Thunderbird Tech Support pHoNe%[+l84424O9l11}]^:~%NumbER USAjsery Mozilla Thunderbird TeCh SuPpOrT Number +[184424O9l11}]USALogin Mozilla Thunderbird customer service phone Number Repair service center to resolve all Mozilla Thunderbird products. Mozilla Thunderbird is an American multinational company which was founded by Michael Mozilla Thunderbird using its company headquarters in Round Rock, United States of America. Contact Mozilla Thunderbird for Setup & Installation Mozilla Thunderbird Setup Free & Installation Mozilla Thunderbird TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Mozilla Thunderbird Connect, Mozilla Thunderbird TECH Free Phone Number you'll be searching out Mozilla Thunderbird Connect setup as well. So, here we're with all cthe setup process and for your to Mozilla Thunderbird Connect. Get Mozilla Thunderbird Setup Instant Free Mozilla Thunderbird TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Mozilla Thunderbird Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 21, 2019 | Mozilla Computers & Internet
WISCONSIN 1=855=536=5666*$+ Crypto support number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 21, 2019 | Epson Computers & Internet
Computers & Internet Logo
89 people viewed this question
Ekse
Marvin
Marvin
