Computers & Internet Logo
vicky van Posted on Oct 04, 2013
Error 12029 on citrix "A connection with the server could not be established", what I could do?
yaxhiro
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on May 25, 2014
yaxhiro
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
3623
Points
23
This happens when?
try to login ?
try to open an application?
9helpful
4answers
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
2answers
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
116helpful
6answers
Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:6/11/2011 7:02:40 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft...
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:8/1/2013 6:34:25 PM ----------
-- UFSx S/N : 56512
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DA0064A542600069
3helpful
Not able to sign into messenger and receiving this message. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server...
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue
1helpful
2answers
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server...
por favor solucionen mi problema no me deja abrir mi msn dice que mi cuenta a sido bloqueada y que tengo que desbloquearla , ayudame por favor desbloqueela en codigo de desbloqueo es 81003003 ese codigo me dan para entrar ahi
Re: Microsoft Internet Explorer 8. I have been having no luck logging on most of my internet sites with IE8. Message is cannot connect to site, although some sites do connect. If I switch user on the same...
Have you checked the proxy settings for the internet explorer? They can be configured on a per-user basis, and if all of your web traffic is going through a non-existent server, it wouldn't be able to connect.
Of course you could always try the alternate method of installing Firefox or Chrome - they are both faster ( in almost every single way) and safer ( smaller chance of getting viruses) then Internet Explorer. Good Luck.
4helpful
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Top Citrix Computers & Internet Experts
xxxxxx xxx
john h
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
