Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
I have a Kenmore 24 inch wall oven model#911.30465893. The start button doesn't work. All other buttons on the control panel work. Is there a safety shutoff, a manual override or reset that will correct this? It seems that if the panel were dead more than one button would be not working.
SOURCE:
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore double electric wall oven
It appears your clock controller/MCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven Model 911.30169792 Control panel lights are on
It appears your ERC/CLOCK has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
  • 9 Answers
SOURCE: My Kenmore Electric Range model 790.9661 seems to
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Posted on Jun 11, 2011
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2013 | Ovens
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
Aug 11, 2011 | Jenn-Air JJW9130DDS Electric Single Oven
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
Control Panel
Joey
Jun 11, 2011 | Kenmore Ovens
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Displays an F5 fault code on kenmore wall oven model 911-47469
HI. This is a touch pad issue. You will need to inspect for binding of the push-buttons and control panel glass. If OK, replace the touch panel board.
Oct 06, 2009 | Kenmore Ovens
Error code f7 on Kenmore wall oven 911.41165791
May 27, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
130 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
