Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Replaced toner cartridge and copy had line of toner on edge -
Reshook and cleaned the toner cartridge and drum cartridge - now copies are partially black
  • 239 Answers
Check the ink modual again.
if the ink is all on the upper and lower lip it needs to be wiped off.
Sometimes when shaking this modual, exessive ink can go on the surface and scrub on the drum itself.
How did you clean the drum?
Nothing should be used except a very soft dry cloth. The toner acts as a lubricant to the cleaning moducal.
Take out the toner modual and see if you can tilt the modual back away so it falls to the back of the modual, this way there will not be so much at the front developer mag roller.
Posted on Oct 16, 2009
Wide black line on copy. replaced toner cartridge twice. Can it be the Drum cartridge? 15,500 copies made to date.
If the line is vertical it will either be your drum or fuser are the most likely causes. Visually check each component for the corresponding line on both the photoreceptor drum and the fuser heat roller.
Sep 19, 2015 | Xerox WorkCentre XL2120 Laser Printer
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
A thick black line of toner accumulates on the right edge of the paper
This is most likely caused by the drum unit. This unit is located just to the right of your toner cartridge. Just remove the toner cartridge first. Now remove the drum unit. Turn it over and look at the blue/green colored cylinder which is the drum. It should be clean. If you see a band of toner on one edge of the drum then this is where your toner on the copy is coming from. You will need the drum unit rebuilt or replaced. While it is out also check the front side of your toner cartridge. Just visually inspect the toner "brush" that runs all along the front side and make sure there are no piles of toner on it. Do not touch the brush or turn the roller.
Good Luck and Thank You for using Fixya.
Jun 30, 2010 | Sharp AL 1631 Copier
AL-1220.......dark (w/ residue ) toner line on left side of copy. replaced toner cartridge, but still showing. having to clean small piles of toner below drum even after replacing toner cartridge. am i...
I would have to say that you are having a problem with your drum unit and or the developing unit. Most likely the problem is in the drum unit. You have a line going down the page. I would replace the drum unit and try to clean below the drum unit... Good Luck..
Dec 26, 2009 | Office Equipment & Supplies
We have a Canon PC 400 copier. When making a
Remove the toner/drum cartridge. Carefully rotate the drum, via the end with gear, to check the edges for toner spots like appear on the copies. If located on drum, GENTLY wipe off with a dry cotton ball. Reinstall cartridge. Check to see that spots are gone. If spots reappear, replace with new cartridge (drum most likely damaged)
Sep 11, 2009 | Canon Office Equipment & Supplies
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
All of my copies have toner on the right edge. How do I fix this?
If it keeps coming back on the drum then replace drum.
Very unlikely that the toner is bad.
Oct 14, 2008 | Sharp AL-1641CS Laser Digital Copier
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
156 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
