Readkeystring@csisregkey@sahpadohopauhkey@@k@z Get the error report cannot find the string readkeystring@csisregkey@sahpadohopauhkey@@k@z
    President:
  • 2,976 Answers
Run a registry cleaner. You have a few errors.
Posted on Aug 05, 2009
What is string of index out of range
Error on string index out of range: python - Stack Overflow
stackoverflow.com/questions/.../error-on-string-index-out-of-range-pyth...
Jul 6, 2014 - Error on string index out of range: python ... while True: url = "No Url"string = input("What is your string: ") string = string + " " for x in string: if x == "h": a .... How do I say car is tilting/leaning in one direction in parking spot?
Nov 01, 2015 | Cars & Trucks
What is undefined string
I suspect you got this error during the compilation or execution of a program. If that is not the case, disregard what I am rambling on about .
A string is a set of printing characters (letters, numbers, punctuation signs). In some programming languages a string variable can be defined. Once you define a variable as a string, you can store a string in it.
Depending on the language the string must be enclosed between quotation marks or some other separators. As for other variables, string variables have to be defined before they can be called.
Go to the location where the error occurred and check your inputs, arguments you feed to functions, etc.
Dec 30, 2013 | Canon Office Equipment & Supplies
Display error string module not found
power adapter does not cause :
Display error string module not found, somthing is wrong with your graphic card
Nov 24, 2013 | Toshiba Satellite 2435-S255...
We are creating a crystal report using asp.net and the report has to be printed on 132 cloumn dot matrix printer, but its skipping few columns, can someone help me how to print the crystal report to a dos...
Make sure you have the right driver (ie mx80). Only one or two drivers will work well in dos. It may also need a string added to the report to force it to go to the dos printer. Another thing that can affect size is the font size or font size must be placed in the header of the report.
Mar 02, 2011 | OKI MICROLINE® ML390 Matrix Printer
Hardware problem occurred
Check to see if the cover arm broke off or has missed the lever that makes it operate when you drop the cover down if this does not do it Let me know I will see if I can find anything else but that's all I can think of at the moment, get back to me if that does not fix it and I will see what I can find for you, do the simple first. Thanks for using fix-ya
Jan 19, 2010 | Agfa SnapScan 1212u Flatbed Scanner
I've installed the latest version of msn yesterday. 5 seconds after i sign in i get the ''Windows Live Communications Platform has encountered a problem and needs to close. We are sorry for the...
Although the solution is being posted months after the question is raised, let this help others having the same Dr.Watson issue.
For this, you can ignore the Error Reporting window, or turn off error reporting so it wont dump your windows drive with GBs of unwanted error dump data. If you are good with Registry Editor, follow the steps below:
Open your Registry Editor and browse to
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionAeDebug . Create a new string value (REG_SZ) with name 'Auto' and enter its value as 0, so error reporting gets disabled.
May be this article should help you.
Oct 06, 2009 | Microsoft Windows Live Messanger
Out of memory error
1. Use with - End With for values
with xlWbk.Worksheets(1)
.Range(.cells(1), .cells(4)).value = "Some Repeated Text"
end with
2. Use following VB code for killing excle at the end:
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal
lpClassName As Any, ByVal lpWindowName As Any) As Long
Private Declare Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal
hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As
Long
Private Const WM_QUIT = &H12
Sub TerminateExcel()
Dim lpClassName As String
Dim iHwnd As Long
Dim iReturn As Long
lpClassName = "XLMain"
iHwnd = FindWindow(lpClassName, 0&)
If iHwnd Then
iReturn = PostMessage(iHwnd, WM_QUIT, 0&, 0&)
End If
End Sub
Mar 17, 2009 | Business Objects Crystal Reports® XI...
Parse error: syntax error, unexpected T_STRING in /home/a4491082/public_html/savefile_php/config.php on line 4
T_STRING is a string error. It usually means one of two things.
1. The string is formatted incorrectly. In your case check on line 4. Make sure if you have a ' that you close it with a '. Same with ". Close all " with another " somewhere. Make sure line 4 ends wth semi-colon ;
2. Usually this is the case. The line above the string it states doesn't have a semi-colon to complete the statement. In your case, check that line 3 ends with a ;
That is why it says unexpected T_STRING which means "unexpected string". The string on line 4 is unexpected because line 3 wasn't closed properly.
Aug 26, 2008 | Computers & Internet
Not able to remove a software
Error Number: 0x80040703
Description:Failed to find dll function: SAM.AddProperty
I am able to load the dll but not call the methods.
The method that is being called from my c++.NET dll is:
void AddProperty(String *name, String *value) throw(...);
Below is my install script:
prototype SAM.AddProperty(POINTER,POINTER);
nResult = UseDLL(SUPPORTDIR ^ "SAM.dll");
STRING sKey;
STRING sValue;
POINTER psKey;
POINTER psValue;
sKey="Key";
sValue="Value";
psKey = &sKey;
psValue=&sValue;
AddProperty(psKey, psValue);
I also tried sending in STRINGS instead of POINTER but that didn't work either.
prototype SAM.AddProperty(STRING,STRING);
STRING sKey;
STRING sValue;
sKey="Key";
sValue="Value";
AddProperty(sKey, sValue);
May 29, 2008 | Computers & Internet
Microsoft Access Query
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Feb 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
David Payne
David Payne
