Question about Acer Aspire 5050-3242 Notebook
Nettwork i have lost my wireless connection, and i can,t use internet
  • jbbrown Mar 26, 2008
    My notebook does not show a wireless network connection. It was there before but only a LAN
  • 35 Answers
On the keyboard there should be a icon for the wireless. Most of the times pressing Fn+The key reactivates the wireless function otherwise there is a button or slider in the front or on the side of the laptop
Posted on Sep 22, 2007
SOURCE:
I dont have a wireless nettwork
I looked at the specs on the HP website and it doesnt seem to have wireless, you will need to purchase a wireless card and install into computer, you can get pci or pci express, both relatively cheap, hope this helps.
cheers
P
Sep 23, 2012 | HP Remanufactured Compaq Presario SR1130NX...
Did pc system restore and lost internet connectivity to router. can connect thru modem. have wireless internet connectivity on laptop. want to reconnect internet to pc without losing wireless to laptop.
run this on your laptop - it should yield the wireless key necessary to connect to your network again.
http://www.nirsoft.net/utils/wirelesskeyview.zip
Sep 17, 2011 | NetGear WGR614 Wireless Router
How can i use internet from wifi
Go to 'Start > Settings > Connections tab > Wi-Fi > Search for Networks'. You phone's Wi-Fi radio will be automatically turned on, and will search for available wireless networks. If, after a while, no network is found (e.g. the network you are trying to connect is hidden, i.e. doesn't broadcast its SSID), tap 'Menu > Add New...' You'll be prompted to fill in the Network name (SSID), and if the nettwork is hidden and/or ad-hoc (device to device). Tap 'Next', and fill in the authentication and encryption types, and the passphrase (if any). Tap 'Next' again, and fill in addtional data (if needed). Then, tap 'Finish'. Select the network you have just created and tap 'Menu > Turn On Wi-Fi'.
After finished, press 'Ok' as many times as needed to take you to the home screen. Launch IE and check if your internet connection is active.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards, Carlos
Aug 06, 2011 | i-mate Ultimate 9502 Cell Phone
Its connected on wifi but if i go to internet it says link not available
The internet connectivity from your wireless bridge has been lost. Check and fix it. It may be due to cable connection to the wireless bridge has been lost.
Jul 24, 2011 | Health & Beauty
I have forgott my nettwork password and need to re-config my wireless WPA encrypted router. The Router has ip adr 192.168.2.1, the prolem is I can not access til adr in the explorer as an url. I have...
1. Connect your pc to the router.
2. Open your internet browser window.
3. In the address box type in 192.168.1.1.
4. Press return key
5. Your browser should now display your routers logon window
6. Default username and passwords are usually 'admin'
regards,
nicam49
Oct 30, 2010 | Dell Inspiron 6000 Notebook
I cant get nettwork on explorer no sites to be found, nettwork on but no connection to any sites.
check and be sure that the configuration file is still intact. be able to ping the external interface IP, the ISP gateway and dns servers
Aug 09, 2010 | Computers & Internet
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
I have to reset the router, because my wireless nettwork has been unsecured...and i want to have a secured nettwork...and i dont know what to do...
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.1.1)
3. Enter the router setup, login and password (login = admin and PW = admin)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 12, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot connect new labtob computer to wireless network
Turn the wi fi switch on your laptop.
first make sure that wireless network adapter driver installed and enable in computer.
Then right click on my network places click on proeprty then you can see your wi fi network adapter.
Right click on it then click on view available networks.
If you find your router nettwork then click on connect.If not found then you have to check in router configuration that wireless is enabled there.
For that connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you see configuration page of router.
Then click on wireless check it is enabled.
Also check That WEP is enabled or not.If enable then you need that wep key for connect network.It is in Wireless security menu.
Then save settings and restart router.
Then it find network.
Let me know if you need more assistance.
Thanks
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
Network problem
go to control panel
network connections
locate your wireless connection and right click on it
left click properties
locate the tick box that says shown icon in taskbar and put a tick in the box
ok everything to return to desktop
your icon should now be in the system tray
Jan 06, 2009 | Computers & Internet
Acer Aspire 5050-3242 Notebook Logo
171 people viewed this question
Ekse
Alun Cox
