Tv ariel just moved into a new property... tried tuning tv in but still cant get no signal...and same goes for new neighbours. ntl used to broadcast in this area... would there be any possability that it could have been switched off.... if so would you be able to supply a number so we can try and get it sorted.
  • 3,866 Answers
Okay most likely your are is in digital conversion area witch your going to need a digital box.. you can get on the goverment rebate/coupon program to take the cost down.
Posted on Apr 22, 2009
Blue screen tv that wont tune into any channels,tried different Ariels nothing works
Tuner fault. It is irreparable. Replace it with same number. Contact any service technician. http://electronicshelponline.blogspot.com/
Oct 28, 2014 | Televison & Video
How to tune a tv
Try the TV in a location where one of the other TVs works. That will show if it's a TV or a cabling issue.
It's entirely possible you have too much power in the aerial signal system. The mux carrying the BBC channels will be one of the strongest at each TV transmitter across the UK. This is because something like 96% of the UK mainland population must be able to receive at least the BBC and main commercial channels to fulfill the broadcasting requirements. Your old TV might not have been so sensitive. The new TV might be more sensitive. So the signal is overwhelming the digital tuner.
Try a variable attenuator. This will give you a power control to reduce the signal as it comes in the back of the new TV without upsetting the other TVs. The MA1620 on this page is perfect for this. http://www.satcure.co.uk/accs/page15a.htm
Splitters amplified splitters and attenuators
Sep 06, 2014 | Televison & Video
How to tune a tv channel
This could be too much signal.
Just to be sure though, try the set in another room where one of the other TVs works okay. This will help you see if it's a cable or a TV signal issue. If you pick up all the channels okay it's likely that that other TV point has some bigger signal losses due to the cabling.
The mux (transmitter channel) carrying the BBC signals will be amongst the strongest at each and every TV transmitter across the land. This is because the BBC and the main ITV channels have to reach about 96% of the mainland UK population in order to the broadcasters to fulfill their remit.
TV tuner sensitivity varies between brands and models. It may be that your old TV was just about okay with the signal power, but the new TV's tuner is over saturated.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Gooman ld2667d tv is not recieving any digital channels, using the same ariel port as before. unplugged the tv to put onto a new stand and getting no digital tv channels. Signal is 0 % too. Before i...
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Aug 12, 2011 | Goodmans 289NS 14" TV
GOT A NEW TV BUT CANT TUNE THE STATIONS IN JUST GET NO CHANNELS FOUND,IS AN OUTSIDE ARIEL MY ONLY OPTION?
You probably need a digital converter box. Analog channels are no longer broadcast over the air. I think you can probably find one somewhere on the internet or at a local cable store/supplier.
Apr 01, 2010 | DMTech DM-AV10 Digital Media Player
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
I have recently moved areas. my toshiba regza 37'' does not tune into the free view chaneels everytime. even when it does the quality is awful. sometimes it does not tune into the bbc related channels....
The most likely problem is the aerial system you are using in your new location. It could be either the position of the aerial needs to be adjusted or the cable coming from the aerial has a problem, check the end connector that goes into the Tv to make sure it is wired correctly. Also check with your new neighbours to find out what quality of reception they have, it's possible you may in a "weak" zone for picking up a freeview signal.
Aug 24, 2009 | Televison & Video
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
My digital tv is now telling me i have no signal or a bad signal and to check my ariel. I am 65 and not able to do this what really is the problem. I hate digital
If you are using an antenna the signal is too weak to broadcast the tv station completely, it is asking you to move the antenna to get better reception, if you are using rabbit ears you can move the antenna pretty easy, if you are using an antenna that is on the roof it's not as easy, if this is the case you can go to an electronics store or Radio Shack and get an antenna booster it should help you
Aug 12, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
