Question about Magellan RoadMate™ 1212 Car GPS Receiver
My Magellan RoadMate touch screen doesn't work any more since I change the settings to simulating mode, now the power cuts off when ever you touch the screen, it restarts itself but as soon as you touch the screen again it shuts off I press the reset button but the results are still the same, the battery also doesn't seems to work if I unplug the power source it cuts off it can only powers on with the adapter.
montecarlo
  • 50 Answers
SOURCE: Magellan Roadmate 800 freezes
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 1111 Answers
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Posted on Jun 12, 2009
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
System.
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
Languages.
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
Brightness.
3. Tap in the brightness slider to set the brightness of the display.
The
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
Magellan roadmate 700
In configuration, under diagnostics, simulation needs to be turned off
link to web site
user manual link
Are maps unlocked?
https://www.magellangps.com/users/keysIntl/ssl_index.asp
Dec 03, 2007 | Magellan RoadMate 700 GPS Receiver
My touch screen is not working. The GPS is on but whenever I touch the screen, tt doesn't respond. I own a Magellan RoadMate 1412
As the touch screen is not working,then you only need to replace a new working touch screen for Megallan RoadMate 1412,you can try to contact:
MSN/EMAIL:kingyijin@hotmail.com
SKYPE:keyudakim
Probably she will give you a good solution for that touch screen.
good luck
Dec 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Switches on but goes directly to system settings - no way back
reset the unit (read your manual link below) if that doesnt work, the digitizer (touch screen) is probably broken.
http://www.magellangps.com/assets/manuals/mrm_1200_manual_en.pdf
Jun 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
Mar 16, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 1412 is set to wrong region, how do i change regions?
At the main Menu, touch right arrow, select "User Options"-->Region and select the desire region.
Feb 27, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Dec 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 2000 will not stop with the demo mode
Go to Simultor option in options sections and touch the screen multiple times and you may see "simulate" button activated and then in the status should show "simulation stopped" and that when this damn thing is back to normal operation. Hope this helps. I was in the mode for last few days and no help anywhere online.
Dec 21, 2007 | Magellan RoadMate 2200T GPS Receiver
Magellan RoadMate™ 1212 Car GPS Receiver Logo
621 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
