Question about Futaba 7c Computer Radio Air R617fs S3152 Servo
Problem to locate the channel after the power is switched on
Hello ! My radio is an Futaba PCM 1024 Wc2 and a module : Spectrum
2,4 GHz DSM2 DM8 FUT . The problem is that efter switching on the power on the transmitter the system have serious problem locating a channel , the other led on the masterreceiver stays''black'' and the servos are in their limitpositions. It is not good for the helicopterlinkage.
I tried 15 times yesterday and only two times it worked !
Please tell me what to do, I bought the radio as used.
Best Regards: Tom Grönholm
  • 2 more comments
  • tom_gronholm Apr 22, 2009
    Hello !
    I tried to move back and forward the antennacable and checked the screw on the module but I couldn´t
    find anything wrong. Is there any tips how I can test it ? Can I mesure something ?
    I did the mentioned testing while the problem was "going on "
    Best Regards : Tom Grönholm
  • tom_gronholm Apr 23, 2009
    Hello !
    I asked my friend about my problem an he said that the problem seems to be a binding-problem.
    I trid to bind it again but no success. Then my friend suggesteg that I should try connect the power the other way (first receiver and then transmitter) Belive it or not but it worked !
    Sometimes I can notice the same problem but cycling the power is enough to solve the problem
  • tom_gronholm Apr 24, 2009
    I have a Raptor 30 V2 electric and a Lama V3
    Regards : Tom
    Hello !
    The electric is my thing, I don´t even ovn a nitropowered
    Tom
    Sergeant:
  • 199 Answers
Dear antina has no work and sometimes service provider has fault/unavailable or you are out of coverage from coverage area.plesae contact your service provider...thanks dear it is not major problem....
OR:
your transmitter has a problem please consult the radio mechanic.
Posted on Apr 24, 2009
  • Aftab Nawaz May 01, 2009
    tell me what r problem are facing you.tell me clearly
  • 3,037 Answers
Yes binding is usually a big killer in R/C transmitters and receivers. What kind of helicopter do you own. I haven't gotten past using the nitro cars and planes yet since I've heard that helicopters are a lot harder to control from alot of other guys. Glad you fixed the problem. Have a great night.
Benjamin
  • Benjamin Patri
    Benjamin Patri Apr 24, 2009
    Very nice, do you mainly go with electric vehicles or nitro?
  • 19,396 Answers
Hi Tom,
That is probably because of a broken contacts to antenna, if no part replacement is required Futaba will repair it for $15, Click here or give them a call.
Posted on Apr 21, 2009
  • Ginko
    Ginko Apr 22, 2009
    If it is a broken wiring to antenna you usually can see it.
    Once you are sure this is the radio problem, but antenna is fine, and also it is not a problem with the chopper receiver, then the best thing to do is contacting Futaba at 1-217-398-0007 , they are available Monday-Friday, 8am-5pm U.S. Central Standard Time.
    The repair will cost $15 plus parts, if this is a bad component it will be $20 or between $30/$40.
    The factory repair is so inexpensive that is not worth troubleshooting the board unless you find a fault at a glance.
    Just do the following:
    Remove batteries and test the radio with fresh batteries (sure you have done it already).
    Ensure it is not the chopper.
    Inspect contacts to antenna , see if you can see broken solder joints on antenna contact. Wiring can be tested using a multimeter set on impedance (Ohms) , if impedance is infinite between two points, then there is no contact:How To Use a Multimeter
    You can also inspect the board for faulty components, but this kind of problems are difficult to troubleshoot without a service manual.
    Unless you find a clear problem on the aerial, if you are sure it is the radio, then the best thing to do is calling and asking a quote on repair,
    Let me know what you think.
  • Ginko
    Ginko Apr 24, 2009
    If connecting first receiver then transmitter worked, then the transmitter is fine, and you won't have the problem on other receivers. Just receiver and transmitter do not have same resonance frequency.
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
I have a 2003 bonniville sle i have a code U1040. Where is the EMCM AND PCM LOCATED
U1040
DTC U1001-U1254 IPC, PCM, SDM
Electronic Brake Control Module (EBCM)
040
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for 5 seconds, a DTC U1??? where ??? is equal to the 3-digit identification number is set.
Control Module
ID Number
016
040
Dash Integration Module (DIM)
064
HVAC Control Module or IPM
065
Rear Integration Module (RIM)
066
Inflatable Restraint Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Head Up Display (HUD)
098
Radio
128
Remote Playback Device - CD Changer
130
Digital Radio Receiver (DRR)
137
Vehicle Communication Interface Module (VCIM)
151
Driver Door Module (DDM)
160
Front Passenger Door Module (FPDM)
161
Left Rear Door Module (LRDM)
162
Right Rear Door Module (RRDM)
163
Memory seat Module (MSM)
166
Driver Door Switch Assembly (DDSA)
170
Remote Control Door Lock Receiver (RCDLR)
176
Theft Deterrent Control Module
192
The electronic brake control module is communicating , no need to bother the PCM . The code was set in pcm because it lost communication with EBCM , PCM not the problem .
Left Front lower corner of the engine compartment, under the air cleaner housing .
Check power's an ground's . Will a scan tool talk to it ?
Oct 03, 2016 | Cars & Trucks
I Have a Futaba SkySport 6 Aircraft Transmitter. But the Manual is missing. Do you know where I might get a manual ?
You can try this link manuals.hobbico.com/fut/6va-manual.pdf. Hope this helps you.
Jun 30, 2011 | Futaba Toys
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
Need a mnual, unable to locate mine
You can get the manual on the link below. If that is not you radio please give the correct model #.
http://manuals.hobbico.com/fut/6exh-manual.pdf
Apr 17, 2011 | Futaba 6CH Digital Transmitter and...
Plugged in charger and got not light on charger for transmitter. Replaced rechargable batteries with AA's turned on transmitter not lights on transmitter. Rechecked polarity on batteries and they were in...
what charger?
it needs to be designed for that particular transmitter, four cells, reverse polarity to Futaba and Hitec
http://www.rcgroups.com/forums/showthread.php?t=839823
Apr 05, 2011 | Spektrum Dx5e Dsm2 5-channel Air Radio and...
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
Oct 10, 2009 | 2003 Ford Explorer Sport
Futaba 7c Computer Radio Air R617fs S3152 Servo Logo
150 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Futaba Toy Expert? Answer questions, earn points and help others
