Question about Infogrames B-17 Flying Fortress for Windows
Problems with my Flight Yoke or the game
Does B-17 Flying Fortress, the Mighty 8th! for PC, works
(or is it compatible) with my Saitek Pro Flight Yoke System?
I think, I tried everything possible, to make it work but with no success...My Flight Yoke works very well with other Flight Simulations except for B-17.
All I need to know is; if it is compatible with the game or not?
if it is, I'd like to know how!
Thank you for your time
Patrick
  • Butch_N Apr 21, 2009
    I had the same problem years ago with this game. I gave up and moved on to IL-2
    I think there were problems with usb joysticks. However, I seem to remember that there is a workaround for it, or a config edit, something like that.
    So there is a possible solution.
    Maybe try asking at SimHQ.
    http://simhq.com/forum/ubbthreads.php/fo...
    Not a very active forum, but chances are someone will drop in that knows how to get you up and running.
    Good luck
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Nov 08, 2012 | Saitek Pro Flight Yoke System Flight...
I have a simple problem with the SAITEK pro flight yoke. The LED display does not turn on. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LED DISPLAY. ...
For how low have you had the Yoke?
This a known fault with the front display on the Yoke failing, it's caused by the LED's being faulty or a inperfect contact there.
If the Yoke functions correctly then it might be one of the above.
If you still have warranty, meaning if you purchased the Yoke less then 2 years ago, try to ask for a replacement for it either from the retailer of from Saitek.
hope it helps...
Apr 03, 2011 | Saitek Pro Flight Yoke System Flight...
I purchased a Saitek pro yoke online and when I turn the control to the right it squeaks, is there a solution for this problem.
Rub a shoe shine pad on the yoke shaft. These pads have silicone on them and it will act as a lubricant until the yoke beds in.
Jul 08, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
Jan 01, 2010 | Saitek Pro Flight Yoke System Flight...
Reprograming the Pro Yoke Hatswitch
Go here --
http://www.fixya.com/support/p921647-saitek_pro_flight_yoke_system_flight_sim/manual-27479
Hope this helps..
Mar 24, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Infogrames B-17 Flying Fortress for Windows Logo
50 people viewed this question
Top Infogrames Video Game Consoles & Games Experts
newclique
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
EnergeeUK
Level 1 Expert
Are you an Infogrames Video Game Console and Game Expert? Answer questions, earn points and help others
