Question about Craftsman Garden
Grass bagger for riding lawn mower
What is the correct 3 bagger unit for the sears/craftsman riding lawn tractor/bagger, with a 46'' deck; model # 917.256660!
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
GM Elec
  • 1000 Answers
SOURCE: Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Posted on Jun 12, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for a Sears Craftsman II 12
Go to the above address, type in your model number
917.257280 just like this with a dot not a dash it will locate the tractor for you, go to the list on the left side of the page and select >>38" mower<< at the bottom of the Sub-components list and it will show you a picture of how it looks installed as well as all associated parts
Posted on Oct 03, 2009
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
What type of oil filter do I need for a lawn tractor 24H.P. 46" mower Model #28857
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Jun 27, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to raise crafstman tractor deck
Your deck is not installed correctly. If you have the operator manual, check everything. If yo dont have the manual ... go to www.sears.com/support and get one.
May 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
256 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
