Question about Ruud Central System Air Conditioner
New 2P 30A contactor, not labeled with "T" and "L" ends.
I am replacing an old 2 Pole, 30A 24V Honeywell contactor with a new Square D one. The new contactor is perfectly symmetrical, with coil terminals on both sides, and is not labeled with specific T and L ends. Am I right in assuming that either end of this contactor can be "T" and "L"? (I.e., which way I install the contactor doesn't matter, as long as all of the wires go to the same ends as before.)
  • pmrowley Apr 21, 2009
    Sorry, this was posted in the wrong area. I'll close this and repost in the general HVAC area.
  • Ken Bledsoe May 11, 2010
    You are right.
    Novelist:
  • 189 Answers
It will work either way....
Posted on Apr 21, 2009
  • 358 Answers
Yes you can use either end of the contactor , but put all the wires in the same place they were before doing it one at the time.
Posted on Apr 22, 2009
How can you find the model number for our Ruud Achiever 10 since the outside label has unreadable now? Our house was built in 1994.
just get a double pole contactor and rewire using existing contactor to wire new one ,, contacters are generally generic
Jun 22, 2014 | Ruud Matching Split Air Conditioner
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
I need to put a 24 volt coil relay in my furanace for an EAC and I'm not sure how to hook it up. I'm guessing the low voltage wires from the thermostat (w & b wire) will go to coil side and...
Electricians don't guess, they test.
Usually 'relays' used for HVAC are called contactors, for some reason.
1) 24Volt wires connect to coil. Make sure contactor coil is rated 24Volts or 24vac
Coil terminals are typically located on side of contactor.
Usually you can see small copper wires from coil that are soldered to these terminals.
Test across terminals with multimeter set to read ohms, and you will get ohm reading of coil.
2) The 120V or 240V wires connect to terminals located on ends -or- on top of contactor.
If there are three terminals, then check these terminals with multimeter.
Push down contactor to simulate the contactor turning on and off.
Hold contactor down and test terminals again.
And compare test results with same test from old contactor being replaced.
3) Open following link to see typical 24V coil contactor with DPST with 2 NO contacts
The contactor shown in diagram is similar to your contactor, except the contactor shown has 4 terminals for 120V or 240V. This is why testing contactor and comparing with old contactor is necessary.
http://waterheatertimer.org/images/ON-delay-timer-diagram2-300.jpg
Sep 20, 2011 | Honeywell International Honeywell...
Where can I get a double pole contactor for my goodman ckl60-1
I buy all of my contactors at www.grainger.com
Match up the coil voltage 24v
The number of poles 2
The contactor rating...in this case it should beat least 40 amp.
You can find them buy searching the site for "definite purpose contactor"
They are very efficient and will ship quickly from the closest warehouse...I usually have my stuff UPS the next day.
heatman101
Aug 25, 2011 | Goodman CLQ36AR49 Air Conditioner
My Contactor went out on my UPKA-031JAZ I went and was told a Honeywell DP1030A5013 contactor would replace the one that went bad. So how do I wire the Honeywell to the old one since they don't look like...
this is a single pole contactor, Look at them both closely, Notice that there is a bar which goes directly from one side to the other, note all the leads that are connected
mechanically from one end of this bar to the other including the spade connections.
On the other "Leg" there is a similar setup. In this case the contactor breaks the
connection (It may have a bug cover). All the leads on this leg make connection when
the contactor is closed including the spade connections at each end. It is a big switch.
The 4 spade terminals on either side are the ones which control the coil.
Make a drawing and take a picture with your cellphone to remember where each
wire goes.
I remove the wires one at a time and switch them out. Make sure power is off to both
the inside unit and pull the disconnect for the outside unit and check before servicing.
They may look different but if you pay attention to the orientation of the solid bar
it should become apparent. Hope this helps.
Apr 26, 2011 | Heating & Cooling
I have CK49-18. I am looking for replacement double pole contactor for a do it yourselfer without a license.
Hi.
Go here to get that contactor... from what I can tell from your model number you need a 24v coil and a 30-40 amp rating on that contactor...
heatman101
Aug 30, 2010 | Goodman CKL49AR49 Air Conditioner
The unit will not start for the summer. It worked last summer.
Open the control box and see if you have around 220-240V at the bottom of the contactor. The contactor is the switch looking thing in the bottom. If the unit is calling for air it should have a button in the middle that is pulled in. If you are not getting the volts at the contactor then you need to find the electrical problem.
If you have the correct voltage then look and see if the contactor is connected. The middle button should be pulled in. If you have one where you are unable to see the button, or it is not pulled in, Check the low voltage wiring. This is done by checking to see if there are 24V-28V on the side terminals of the contatcor. These terminals are located on the sides of the contactor. (some contactors have both sides of the 24V on one side.) Either way you should read 24-28V when checking across the two terminals. If you do not then you have a problem with the control wiring. (cut with weed eater, chewed by mouse etc.) I know the 24V coil is good because the inside unit is running. If the contactor is pulled in and the outdoor unit still does not run check and see if there is power at the other end of the contactor. (The end the switch breaks off)
If the switch is pulled in (or you read 24- 28V on the side of the contactor, and there is 240 V coming in on the line. Chances are you need to replace the contactor. Disconnect the power and pull one wire at a time of of the old contactor and install it on the new. After all of the wires are on the new one, remove the old contactor and throw it away. Screw the new contactor with all of the wires back onto the unit. restore power. Often times in our part of the country, there will be ants stuck in the points of the contactor. Just cleaning the contactor will buy more time.
Hope this helps.
Jul 11, 2010 | Carrier 38CKC024 Air Conditioner
I need assistance with swapping out a contactor.
I don’t believe changing the contactor to a double pole contactor will solve this problem. It appears by your description that bugs are being attracted to the contact points on the contactor. Changing to a double pole contactor will not eliminate that problem but only provide another contact point for the bugs to be attracted to. The most effective solution would be to replace the current contactor with a sealed design where the contact points are totally enclosed. Enclosed contactors are completely enclosed protecting it from bugs and dirt. These type of contactors are available in the single pole design so no further wiring modifications are needed. You can consult a professional A/C service company like mine for more information and assistance.
Hope this helps. Let me know if there's anything I can do for you!
Sam, The Service Expert
Visit Sam's Blog
1.888.HEATCOOL
ServiceExperts.com
Apr 30, 2009 | Ruud Central System Air Conditioner
Carrier A/C units
Double check that the new contactor has the same electrical ratings on it. My guess is that the coil should be 24v while the relay should be able to carry the same amperage at 220v.
First shut off the breaker and disconnect switch for the furnace and outdoor condenser and call a licensed HVAC contractor:)
If you are determined to do it yourself, Then read the schematics first. Be aware, if you mis wire the system you may cause more damage than you have now. Not to mention your personal safety is at risk.
I am basing this on the most common style contactor found in my area.
The main relay side should be labeled. (eg. L1,L2-T1, T2). These should match exactly like the old one. L1 and L2 are the incoming power. T1 and T2 are the power leaving the contactor. All the 220v wires should correspond to one of these four terminals either by screwing them down or fitting the spade connectors together.
Usually the 24v wires will plug onto the coil (near the bottom, left and/or right sides of the contactor) silver spade connectors.
(STEP 1.) Leave all Wires Connected to your Old Contactor.
(STEP 2.) Remove the two mounting screws that hold the Old Contactor to the Air Conditioners casing.
(STEP 3.) Now Install the New Contactor to the old contactors existing location using the Same two Screws.
(STEP 4.) Now take Off one wire at a time from your old Contactor and Install each wire one at a time to the proper location on the new Contactor.
Jun 24, 2008 | Carrier 38CKC042 Air Conditioner
Ruud Central System Air Conditioner Logo
122 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
