Question about Hitachi DVD/HDD HYBRID 30GB 2.7 WS LCD *NIC* 30 GB USB 2.0 Hard Drive
Dz-hs500a It's rather new cam. only 1,3 month. it doesn.t swich on. I got new , more power betery,nothing! What could happened??? May be it's becouse batery i bought on line??
  • Anonymous Nov 25, 2007
    Won't power on. Just got the camcorder. Used it a couple times, now can't get it to power up. Manual suggests a "reset" button, which I tried, no luck. Tried 2 charged batteries and AC power, nothing works.
  • Studio3 Jan 15, 2009
    While recording some footage the battery died. An hour later I swapped the dead battery with a charged one and tried to turn it on and all it would do is show an infinite loop of the "Hitachi DVD HDD" startup graphic. I turned the power switch to the 'off' position and the loop continued to play until I removed the battery. Then I connected the AC adapter and tried to turn it on again; same result. I consulted the manual and it mentions removing all power and holding the reset button for "several seconds" then trying to power on again. I tried this and the only change was that the camera beeped as it turned on (I had this feature turned off, but the reset changes all settings to factory defaults, so this was expected) and resumed the infinite loop. After this I disconnected all power sources from the camera and let it sit for 12 hours before trying again and getting the exact same result.
    Am I left with no other choice than to take/send it to an authorized repair center?
    New Friend:
Borrowing the Hitachi dvd/hdd to video a wedding this weekend. The dvd disks i've tried won't play on any of my computers or dvd players. help please! thanks a bunch
Posted on Apr 04, 2011
SOURCE:
I have a binatone sat nav for seven months and now i can not swich it on , when i press button nothing happens
The Web site below is a Forum for this product that has links to User Manuals and troubleshooting problems. I hope it will solve your issue.
http://auto.manualsonline.com/support/binatone-electronics-intl-ltd/gps-receiver/
Sep 03, 2016 | GPS
How do i get the computer to come out of power save
1. Swiched CPU power off (But Monitor on - though blank )
2. Removed motherboard battery(its like a watch battery but quite bigger)
3. Then Swiched th CPU on
4. On screen message ( the I pressed F1 on the keyboard) .
now see what happen.
Aug 15, 2012 | HP Computers & Internet
My tower is plugged in and the monitor is plugged in but my windows will not show up on my monitor. It says to hit a key to get out of power save but wont do anything
Hitachi mini dvd cam will not eject disc, will not read, will not write, will not record. Also cannot read mini disc on Windows Vista, is there a driver for either of these issues?
This has happened to me many times. The disk has an error (they alway do).
1: Turn it off.
2: Attatch power connection.
3: Hold down eject button.
4: It should say: "DISK ACCESS"
5: It may take a long time, but put it down in this state and leave it for as long as it may take.
6: Later on, it will eject the disk.
7: Discard of this disk, it's nothing but trouble.
Aug 18, 2010 | Hitachi DZ-MV230A DVD Camcorder
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
I live in Brazil. I bought a DZ-HS300A. The PC not recognize the cam. I plug the USB cable and nothing happen.
How old is the camera (USB1/USB2)?
Are you behind a USB hub?
Have you tried multiple USB Ports on computer as watchdog may have them timed out?
Did this device require OEM drivers that needed to be installed prior to device installation?
What version OS are you running?
Feb 19, 2010 | Hitachi DZ-HS300A DVD Camcorder
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
After the coffee is made, the water seems to continue to heat
check this:
  1. termo swich,
  2. swich for steam
  3. termoswich for steam
replace with new if thay does not work good, and obligatory put one new TERMOFUSE for your safety, becouse she does not trigered obviously.
Apr 01, 2009 | Bunn VPR Coffee Maker
My hitachi dz-mv730a won't eject
did u tried to press the eject button for a few seconds (~20sec) wait & see what will happen. or better you use a direct plug of AV adapter. maybe theres a need for additional power on your cam.
Sep 04, 2007 | Hitachi DZ-MV730A DVD Camcorder
Hitachi DVD/HDD HYBRID 30GB 2.7 WS LCD *NIC* 30 GB USB 2.0 Hard Drive Logo
96 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
