Question about Ellington SBF58AN5LKRCR2 Surfboard Antique Nickel Ceiling Fan
How do I make the fan reverse with RCR2 remote. Lost manual.
Can I get another manual? Don't know how to reverse fan with remote RCR2.
    President:
  • 1,489 Answers
The fan should have a switch on it to set it for clockwise and counterclockwise direction. The remote usually does not control the direction.
Posted on Apr 21, 2009
How to manually reverse ceiling fan direction.
You did not provide a make or model of your fan, but check your owner's manual if you have one. There should be a website or a service support telephone number to obtain more information. Most ceiling fans have a reversing switch on the fan itself. They can be a pull-chain type or a slide switch.
Jul 25, 2015 | Dryers
How do I reverse the fan for winter use. I have a Caswick model with remote but have lost the manuel
On most fans, there is a small switch or button on the housing that you can slide up or down, depending on whether you want the fan to blow air up or down. For winter, you would want it blow the air up, to enhance your air circulation.
If your trying to find the correct button on your remote, look for one that says reverse or up. That should do it.
If you still need a manual, try going to "Manuals Online". They can provide most manuals your looking for.
Mar 14, 2011 | Vacuums
Fan does not reverse. the wireless remote does not have a button to reverse the fan nor the chain pulls cause the fan to reverse direction. is there such a thing as technical support for hampton fans ?
Only the remote decides when the fan reverses. Weird, I know. Depending on room temperature and selected temperature (on the remote), the fan will reverse direction. For example: If you set the remote temperature (set temp.) for 74 degrees and the actual room temperature is 70, the fan will reverse to bring the warmer air (which is always closer to the ceiling) down and warm the room until the set temperature is reached, then the fan turns itself off. The remote monitors room temp and selected settings and repeats the cycle.
Oct 15, 2009 | Dryers
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Jan 23, 2009 | Minka -Aire Brushed Nickel Remote Control...
UC7078T Remote
try opening remote control
vary (4) "dip" switch(s) positions
when I opened mine-all four were up
I moved the 2nd switch down and it worked!
Aug 15, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 54in. Covington with remote...
I have this fan with the remote. The top right-hand switch on the remote says fwd/rev and that does, in fact, reverse the direction of the blades. The manual says to make sure the fan is still moving when you press this switch or it won't reverse direction.
Jul 10, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Ellington SBF58AN5LKRCR2 Surfboard Antique Nickel Ceiling Fan Logo
191 people viewed this question
Top Ellington Dryers Experts
john h
Bill Boyd
Are you an Ellington Dryer Expert? Answer questions, earn points and help others
