Question about HP Deskjet 6940 InkJet Printer
Cannot install 6940 driver
I get error message when trying tio install that says 256 mb ram required for installation - computer has 256 meg ram but instakker says it has 254 mb - can i get around this without adding another memory module
    President:
  • 414 Answers
This is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Posted on Apr 21, 2009
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
I have a deskstop while am put new os for my computer in the drive capacity was just 15 gp in that all the process will completed after the computer will get started there shown the message (there is low...
FIRSTLYThe error shows that your RAM is less i.e. 256 MB not your hard disk. You have a hard disk with capacity of 15 GB but your RAM is 256 MB only. You might be installing either windows Vista or Windows 7 because your system does not meet the minimum system requirements. You need to upgrade your system hardware or you can install windows xp.
SECONDLY You have to install the windows in your desktop only because if you install the windows in your laptop, then all the device drivers will be installed for your laptop only. So it is mandate to install the windows in your desktop only until you are using any third party tool.
Regards
Manjeet
Jun 14, 2010 | Dell (002TR) Motherboard
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Upgrading ram in a dell 5150 do I need to install 2 menory boards of the same size at the same time. I have two 256 mb and I am trying to install 1 512 mb to expand the menory to 1 gb It works for awhile...
you have 4 memory connectors. the maximum memory the computer supports is 4 GB. it is recomended that you install in pairs, for some reasons, but i have installed and i have seen it doesnot matter at all. you can go ahead and install the memory for whatever size on the computer. make sure the bus speed should be either 400 or 533 MHZ. and yoou never explained the error message. when you upgrade the ram you will get a message the system memory has changed press f1 to continue or f2 for setup just press f1. if the error message is in windows after you click on your name it has nothing to do with your memory. if its before that. than try to reseat the memory. installing memory in non pairs doesnot cause any problem most of the time. explain the error message only than i can guide you furthur.
Oct 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Pc gaming issue
i,d suggest your problem, is with either the Graphics card. Or your Memory is very Low. I,d go 512 meg RAM ( minimum ) Go To 256 Meg ( AGP Or PCI-e Card ) minimum.
Install Direct X 9 Or 10 if the new card supports It.
Also check The Speed of the Memory.
Final solution, is to free up some items From The start-Menu.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 19, 2009 | Dell Dimension E520 PC Desktop
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
HP Deskjet 6940 InkJet Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
