Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Where do I get a PWB-signal 930B923002?
I previously posted the blue screen with sunburst pattern problem. I replaced the lamp and still have no signal - just a blue screen that is flickering and flashing. After reading simular posted issues(blue screen with no signal), many suggestions were to replace the PCB Signal 930B923002. I suspect this is what is wrong with my unit, but where do I get this part? Mitsubishi's website only shows how to order lamps and remote controls.
  • todd blakley Nov 09, 2007
    i HAVE A SIMILAR PROBLEM WITH MY WD-62525, IT HAD A BLUE SCREEN WITH STATIC IN THE MIDDLE, IT SAID COMPONENT CABLES WERE IN VALID, I SWITCHED THEM AROUND WITHOUT ANY FAVORABLE RESULTS, THEN I WENT AND REPLACED THE LAMP TWICE, THE FIRST TIME I GOT RED LAMP SIGNALLING A LAMP FAILURE, THAT WAS THE REASON FOR REPLACING LAMP AGAIN, STILL AFTER A COUPLE OF MINUTES I GET RED LAMP AGAIN, IS THERE A PROCEDURE TO RESET LAMP TIMER ???, I TRIED SYSTEM RESET TO NO AVAIL. THEN I HAVE TO TRY TO FIGURE OUT THE OTHER PROBLEM ONCE I GET MY BLUE SCREEN BACK.
  • 3 Answers
You need to find a local servicer to order parts for you.  It seems like a gamble to replace the signal board without further troubleshooting.  Minimally, you should check your power board for swollen capacitors, as this has been a common problem.
Posted on Oct 12, 2007
    Genius:
  • 1,694 Answers
Try alldatadiy.com or acrobatfiles.com/mitsubishi or splodeman.com/Mitsubishi
Posted on Oct 09, 2007
  • Vista Electronics Oct 18, 2007
    Call 1-800-553-7278   Mitsubishi parts
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
4.5 year old set, replaced lamp one year ago. Been an excellent and trouble free set. Now seeing blue horizontal lines appear (mostly on black screen). What is this?
The Control PWB only causes this defect when the Backlight Control Signals are Output from the Control PWB No LVDS(Low Voltage Differential Signaling) signal may also result in this symptom
Oct 18, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sunburst pattern on blue screen
Lamp is bad. Where did you buy it? Did you use the Mitsubishi part?
Only Blue Screen
1. Suspect the Signal PCB part # 930B923002
Aug 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
