Question about Hoover F7431-900 SteamVac Vacuum
Owners manual for a f5815 steam vac
Need an owners manual (online please) for a hoover f5815 steam vac
  • kellycarson1 May 24, 2009
    same sucky thing.Hoover steam vac. New but do you think i kept manuel?oh ok
reddevil6
  • 1673 Answers
SOURCE: hoover F5815 Steam Vac
Won't be any steam, just the hot water that you put into the tank.
Posted on Jun 21, 2008
SOURCE: need manual for Hoover steam vac. F5910-900
For an appliance or any kind of electronic,
I would try http://userguides.50webs.com/
Posted on Aug 24, 2008
SOURCE: NEED MANUAL FOR HOOVER F5909-900
They say that some machines have the same manuel for more than one machine. You can try another seriel number to match the machine you have.
Posted on Oct 03, 2008
CorvetteKing
  • 108 Answers
SOURCE: lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Posted on Jun 14, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
We need a user manual/directions for a f5905-900 hover steam vac clean surge.
Hi There,
Unfortunately the Hoover F5905-900 is a little outdated, and Hoover doesn't have that model on their site. They do however have the Hoover F5906-900 instruction manual which I linked below. This model is identical to yours, and will explain all that you need to know.
If it's parts that you are looking for, here's a link to the parts for the Hoover SteamVac on our website:
Hoover SteamVac Parts & Accessories
If it's something else that you need help with, please don't hesitate to add a comment on this page with your question/concern and I'd be more then happy to help you out.
Here's the link to the owners manual:
Hoover SteamVac F5900 Series Owners Manual
If this answered your question, please be sure to rate the repair helpful, or leave feedback for me, this is greatly appreciated by the Fixya community. Thanks again!
Chris Jones
GoVacuum.com
Jun 09, 2010 | Hoover F5906-900 Upright Steam Vacuum
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
http://www.hoover.com/pdfs/manuals/F5505.pdf
Thank you, this is really appreciated.
Chris J.
GoVacuum.com
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
How do you start using the F5815 Hoover Steamvac? I can not find the direction manual.
This link should help
http://www.fixya.com/search.aspx?cstm=0&_s=F5815+Hoover+Steamvac+Manual
Jim
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Lost manual for hoover steam vac
Best of Luck
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need a Manual
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Do n ot forget to leave rating.
Thanks.
May 30, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5815 Steam Vac
Apr 10, 2008 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
1,029 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
