Tedelex EC 30 LCD no 24 volt supply. 12volts is ok
I have checked the chopped mode supply but cant find any problem.
  • Jim Krause May 11, 2010
    Your complaint says NO 24v supply. So what voltages don't you have and what's the original problem?
4 Suggested Answers
SOURCE: my plasma tedelex no sound no picture but power is on
Sounds like (at minimum) you're going to need a new Y sus board. If you're lucky, you won't need the Z sus board, too. Many times they both go out at the same time.
Posted on Oct 28, 2008
SOURCE: Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Posted on Jan 24, 2009
lovejoy91
  • 691 Answers
SOURCE: you said that there is
on the inverter board you should have the12- 24v going to transformers
Posted on Apr 21, 2011
Tedelex EC-4211 LCD tv with no power. Replaced all capasitors still no power on 24, 12 and 5 V. Where do I look for a fault?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 23, 2017 | Televison & Video
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
TV not working
have you tried YOU TUBE type in your Question then sit back and watch the videos that appear .
Dec 26, 2015 | Televison & Video
About the Sony Bravia Kdl55hx800 55" Lcd Tv
The 12 volts comes FROM the power supply board.
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this web site. You will find repair parts kits as well as complete boards there.
Dec 31, 2014 | Sony Bravia Kdl55hx800 55" Lcd Tv
Sony KDL-40S2010 " LCD TVThe monitor is not working. Last week on certain channels it was bitmapping. Volume is on no picture
this is true, check the main board to the power supply board voltage should be 12volts and 5 volts and 24 they should be marked by the plug ,if voltages are there then the main board is your problem,./
Mar 28, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
LT 3751 change the power board still no picture could it be a fuse and what fuse
Hello Jason:
Check the inverter board for blown fuses in will be a micro surface mount fuse, if it is blown then replace the inverter board assembly. The inverter is used to light the back lights of the screen. Also check the supply voltage from the power supply to the inverter should be between 12volts to 30 volts.
Also you if the inverter board checks ok , then your problem lies in the T-Con board this board is at the top to the panel under a shield.
Oct 14, 2011 | Norcent Technologies LT-2722 27 in. LCD...
I have an emachine t2885, when i hit the power button, i dont get any power to the computer, but the keyboard, speakers and monitor lights go on, but no power to the computer, help
I'm going to guess pwr supply 12 volts side. The 5 volts side lights up keyboard and mouse; both get replaced when they fix (replace) the power supply.
The hard drive and dvd player us the 12volts side.
Check 12 volt supply side if low disconnect hard drive check voltage again,, if 12 volts hard drive bad,,, if low disconnect dvd,,, if 12volts connect hard drive,,,if 12 volts dvd bad. of course this scenerio can go the opposite way. Do you know how to use a multimeter? Black box maintence is exciting.
Nov 27, 2010 | E-Machines eMachines Desktop PC
LG Flatron 575MS 15.1" LCD Monitor Need 24 volt power supply
alkarim 15, Are you looking for an "open frame" switcher or a "open frame" linear dc supply. Does it need to have regulated output or if linear type just brute force output.What is the current requirement of the circuit you will use with the power supply? Have you checked www.jameco.com or www.digikey.com or www.newark.com . Does it need to be AC or DC output? 12fixlouie
Aug 27, 2010 | LG Flatron 575MS 15.1" LCD Monitor
Tedelex EC-PD3000 Manual
go to the offical wesite of the manufacter
Sep 21, 2008 | Televison & Video
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
