Problems initializing a upac-gm29 in a 2008 escalade
I'm troubleshooting an install in a 2007 escalade.
It is all stock with factory nav and rse.
A upac-gm29 was installed 3 months ago and has beeen working fine.
The customer cancelled the XM subscription and the upac quit as well.
I have performed the pac-instructed reset on the gm29, and reinitialized the unit with the car, but the factory head unit will onl display "XM Busy"
What do I do now?
The navigation and radio screen on my 2009 escalade is not working and just blinks the home screen. How can I fix?
Chris, they had a few problems with Escalade nav,/radio usually expensive fix and sometimes doesn't last, a lot of people end up going aftermarket.
Feb 21, 2016 | 2002 Cadillac Deville
Nissan Primera Sat Nav problem
Interesting problem, perhaps you might try to do a reset of the system initially. Normally, this ought to revert everything back to factory default but of course all user settings, preferences and configurations would also be erased. Additionally, some models/units would also ask for an entry code before being operational, pls have this available if your unit requires one. An alternative method of reset is to remove power from the mains. But again, as a reset and a code might be required.
Could you possibly provide likewise the exact make and model of the Nav DVD-CD?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 17, 2008 | 2007 Nissan Altima 3.5 Sedan
The dvd is asking for a pass code, is there one>
no, That's a firmware issue. You'll have to take it to a Volvo repair shop and have them update the firmware. They should have received a DVD with an update program on it.
Oct 18, 2014 | 2004 Volvo XC90
Cant get sound out of stock speakers with aftermarket stereo do i have to bypass factory amp
You need a special jumper, you should be able to buy it from a company called
Jun 07, 2012 | 1999 Cadillac Escalade
How to change out D1S HID headlight replacement 2007 Cadillac Escalade
open the hood of your Escalade, unscrew the mounting screws on the top of the headlight assembly
slide the headlight forward
unplug the electrical connector from the back of the head light
Turn the headlight counterclockwise and remove it from the housing assembly
Install the new HiD headlight, installation is the reverse of removal
hope this helps
Mar 03, 2011 | 2007 Cadillac Escalade Two-Wheel Drive
Tube or tubeless??
If the rims are with spokes they use tube.If it has aluminum rims (like a street bike) then you can install tubeless tires
Jun 09, 2009 | 1991 Suzuki DR 650 RS-E
Can't get iPod to play through factory sound system, pls help
u can buy a cable that splits from an audio output into the red and white cables so u can hook it up to anolog jacks
Jan 07, 2009 | 2004 Chevrolet TrailBlazer
2007 Escalade
disconnect gps antenna in the back of nav. system. Onstar is on passenger glove box
Oct 13, 2008 | 2007 Cadillac Escalade Two-Wheel Drive
Can't get past navigator loading screen any suggestions? it's a Nav-Cam 2007
it sounds like a defective unit, but it may just be a corrupted SD card.
Aug 14, 2008 | Evesham Nav-Cam 7700 GPS Receiver
106 people viewed this question
Top BIT Car Audio & Video Experts
xxxxxx xxx
Are you a BIT Car Audio and Video Expert? Answer questions, earn points and help others
