Question about Audiovox 2-Way 14 channel FRS Family Radio Walkie Talkie 2 Mile Radios
Sqeal when talk button is pushed
How do i get rid of or shut off this squeal.
Me nether
Posted on Oct 02, 2011
I can't seem to get the volume to work on the one radio,The background light comes on, but no sound when I talk into the other radio.
Posted on Jul 14, 2010
  • Audiovox Master
  • 1,654 Answers
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
Posted on Apr 22, 2009
05 mustang gt squealing sound motor revving up out of control
sqealing usually drive belts , try spraying each belt seperately and lightly with WD 40 when squealing, whatever one stops sqealing get a new belt fitted
Nov 05, 2014 | 2005 Ford Mustang GT
Mazda protege 2000 squealing from serpentine belt area check engine light on
it is the belt it is either to tight or not tight enough
Dec 14, 2012 | 2000 Mazda Protege
Brakes squeal even when I'm not push the pedal.
It could be something caught in the brake pads or rear shoes. It could be a broken rear drum component if you have rear drum brakes.
Nov 05, 2012 | 2000 Ford Focus
When doing a hard turn it squeals
"WHAT" squeals when doing hard turns? If you are hearing the tires squealing on the pavement, then you may have a suspension or wheel alignment problem. If you are hearing a squeal in the engine compartment, you may have a loose or badly worn drive belt that is running your power steering pump. A sqealing belt can also be the result of a broken or weak belt tensioner.
Jan 24, 2012 | 1991 Toyota Camry
My tv wont turn on you push the button and it makes a lite squeal noise then the light will turn off and on 3 times the turns off
sqealing noise is a general syptom of a shorted horizontal output transistor and a bad flyback. it could be more but as a technician that the first thin i would check.
Oct 30, 2010 | RCA Televison & Video
WIL NOT TURN ON AND IS MAKING A SQEALING NOISE WHEN I PLUG IT IN
need the model number, as squealing for rear projection is different that sqealing in a DLP televison
Oct 30, 2009 | Televison & Video
Loud sqealing tried changing the belt but it still
above your water pump there is a small hose that runs into it there check it make sure it is not leaking that will make it squeal and its cheap doesnt take much water for the belt to slip so?
Sep 27, 2009 | 1997 Ford F150 Regular Cab
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
Squealing
Let me know what you figure. I have changed alternator , water pump and belt on my daughters 2002 Spectra. . Still squeals. Currently assessing battery condition.
Aug 12, 2008 | 2001 Kia Spectra
Electrical
Are you talking about your car or Photoshop?
If its your car I can almost bet the belt that runs the alternator is loose and It sqeals during aceleration. take it in a have someone take a look at it to make sure it is not anything more serious.
Nov 08, 2007 | Adobe Photoshop Elements 2.0 for PC
Audiovox 2-Way 14 channel FRS Family Radio Walkie Talkie 2 Mile Radios Logo
182 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Thomas Perkins
Thomas Perkins
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
