Question about Compaq iPAQ H3765 Pocket PC
My IPaq will not stay charge, will it be that I need to replace the battery? Or what could the problem be?
  • charletta_wi Apr 23, 2009
    EricS777,
    Its not a phone its a PDA and I believe that the battery is over 5 years old.
  • EricS777 May 11, 2010
    how long did you charge the phone when you got it and how old is the battery
That's probably what's wrong. Mine sat unused for five years and the battery wouldn't stay charged either. I bought one on the internet, installed it easily and it works like new.
Posted on Sep 18, 2009
    Guru:
  • 832 Answers
Hi thanks for using fixya!
Perhaps, the error might be in your battery or with the charger itself. Buy a new battery or better yet bring your phone to a service center to check further the battery and your charger, and to know where is the error exactly.
Regards! if you need further assistance, let me know. pls rate me accordingly! thanks!
Posted on Apr 22, 2009
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
Won't stay charged
you might need to replace:
A. the main Li-Ion battery
B. the backup Ni-methal battery.
or maybe C, fix your battery cover.
that's it! great device btw..!
Aug 28, 2009 | HP iPAQ H4150 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My iPAQ 5555 won't charge.
well that's really the problem when u go ur phone stocked for a weeks or two. i have my advice.. try charging yout battery manually. how is that? modification is needed. remove your battery from ur phone. and connect it to your charger directly.. (how is that? create a wire that can connect your charger to your battery. make sure u connect the right polarity) in this way your battery will charge for a moment and will give enough power to turn on your phone. because showing up that orange thing when charging up needs an initial power. so that is why. but still u can charge your phone. just live it maybe for an hour. it may work!
Aug 16, 2009 | HP iPAQ H5555 Pocket PC
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
Back up battery
 recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter or insert a fully charged battery into the HP iPAQ.
Oct 07, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq will not Charge
Those batteries only last about 2 years. It's probably time for a replacement.
Feb 15, 2007 | Compaq iPAQ H3870 Pocket PC
Compaq iPAQ H3765 Pocket PC Logo
222 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
