Question about Technics SL-1210 Turntable
1 X 1200Mk2deck higher volume / causing spkr not to work..
Hello.
2 x technics 1200MK2
Problem 1
One deck is producing a much higher volume than the other. And i mean much higher. the higher colume deck seems to be fine normal settings on mixer and amp = decent sound)but the other deck is barely registering a sound on my mixer. although there is a tinny sound coming through the speakers still. If i raise the mixer master volume i can increase the volume but it remains tinny and you can clearly hear a major amount of feedback. any suggestions???
Problem 2
In the past i have had issues with one speaker not working. I have cross checked and swapped channels etc etc. The speaker works fine when using any other fundtion on the amp (md, cd, tape, etc, so the amp amplifier isnt at fault and nethier is the amp speaker channel and neither is the speaker) but when i use the aux and input my mixer it ceases to produce any sound at all. the mixer is brand new and works perfectly. In the past when this has happened, I have unscwed and rescrewed the needle on the problem deck mentioned in problem 1, and as if by magic the speaker actually works. then as if by magic it stops working. I would like to sugest a prob with the RCa cables on problem deck and might this explain problem 1 as well!!??? Or could it be tone arm??? Earthing?
HELP
Problem 3:
Pitch light fader on good deck is constantly on faintly though it becomes much brighter when i position the fader at zero?
Ben UK
  • lemondj Sep 14, 2009
    Thanks for your comments. I have fixed the problem. It was a cable issue. Like i had explained, I had done all of the investigation and got someone to replace the phono leads. works a treat......
    Payed through the nose for it though which is why I have decided to take my deck apart, learn the insides and do all repairs my self from now on...
    Thanks
  • richard vreede
    richard vreede Aug 15, 2014
    All won't happen or you haveca boughtv goodcscope and education, but indeed, is the technics easy... Allways replace those standard rcacables and tone-arm wires and recap the unit, since their old . I don't think a straight tone-arm excist on a 1200 mk2 second hand table:), they ain't expensive and replace the cheap Potentiometres on the deck, they are really bad.
    Brigadier General:
  • 8,546 Answers
Problem If you swapped the two TT's would the problem stay with the connection on your mixer? At least then you/we would know wherein lies the problem. I'm betting thge low volume is because you have the phono jacked into a line level input like AUX instead of PHONO.
Typically, what you're describing is a phone source plugged into a NON-phono connection. (Tinny, low volume - classic lack of a phono preamplifier with RIAA equaliztion). A standard old-school tuntable requires a phono preamp that is labeled "PHONO". Nothing else will give it the boost and freq response correction LP's and phono cartridges produce.
Your problem #2 alludes to a channel problem with a turntable running through your mixer. This isn't rocket science. Swapping the two turntable channels around would probably change the apparent failing channel, right? Yes - Problem out at the turntable. No - problem in the mixer. You've already hinted at the source by monkeying with the tonearm wiring. You're on the right track. The tiny multi-colored wires in the cartridge shell are very thin and delicate. Their brass fittings sometimes oxidize and reseating them as you have done usually gives some relief. Kinks in the wires could cause your intermittent symptom. At the RCA end of the tonearm cables, make sure they're seated on with a twist to wipe off oxide.
Problem #3. Is it just bothering you or is there a functional problem, too?
Posted on Apr 21, 2009
Hi there, i just bought 2 Technics mkii
well" for a start, they need to go into a phono socket, this amplifies them.
i take it you bought 2 decks with the intentions of mixing, so you gonna need a mixer.
MIXER & DECKS SET UP:
1.decks into phono channels 1&2
2. black GROUND wires, go to GND screw on back of mixer
3. RCA master / booth Outputs on mixer to AUX / LINE-IN on amp.(not phono)
Oct 09, 2013 | Technics SL-1210 Turntable
Hi, I'm digitising my old cassettes. I have a
Just connect the line outputs from the tape deck to the line input of the computer using a dual RCA to mini stereo adapter if necessary. Your processing software will correct any deficiencies and produce satisfactory results. Be sure to copy the original tape information before dumping the old tape; otherwise you will have a "mystery" CD
Sep 08, 2013 | Audio Players & Recorders
Technics SL1210 mk2 loud hum, it's not the rca or grounding cable...
This normally happens when the carts are removed and the amp is up. Its called microphonic-ing. Cheers john. Styluscity.
Apr 15, 2012 | Technics Audio Players & Recorders
Why does my tuner shut off when the volume is turned up to 40?
does it turn off and then back on repeatedly at higher volumes? if you back the bass off will it allow you to turn it higher? if so i would think your impedance is off causing the amp to overheat or the power requirements for your speakers are way higher than your amp can produce
Oct 12, 2010 | Onkyo TX-SR605 Receiver
When i make phono input..The Volume come very big.And all other input selecter volume come normal.
As long as the phono input is only being used for a record deck the most likely cause is a faulty magnetic cartridge pre-amp. If you are connecting any other device to these sockets, remove it and place it in another socket. If you haven't got enough sockets you can get a switching box to solve the problem. If you are getting the problem due to a record deck, make certain it hasn't got a built in pre-amp first, check the cartridge and wiring to it and all deck connections. If still no luck then you will find that you need to replace the pre-amp. It will be a single IC, which can be found by following the wiring from the phono sockets inside the amp.
Sep 14, 2010 | Technics SUV500 2-Channel Amplifier
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
Hey... my problem with the technics m5g is that the volume is higher on the left side and lower on the right side. can me anybody explain what´s the problem ist?
Most sound problems are caused by cartridges. However in some cases the deck is not to blame, but the amp it is connected to is. If you have another amp make certain the problem is with the deck, by trying it on that first. Remember that other devices can work fine on your amp, but the turntable might not. This is because your amp has another pre-amp just for turntables. It could be this pre-amp that is causing the problem!
Jan 18, 2010 | Technics SL-1210M5G Turntable
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Apr 05, 2009 | Audio Players & Recorders
Annoying sound
i forgot to mention,when i take the belt away from the mechanism that turns the deck,the scratch noise stops..
Jan 15, 2008 | Panasonic Technics SL-BD22D Turntable
Technics SL-1210 Turntable Logo
255 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
