Question about Bialetti Mukka Express
Coffee has started becoming weak
I have a Bialetti Mukka Express - lately the coffee has started becoming weak and the foam is less too. I am not sure if I need to replace the filter or gasket. Please advice.
  • Bialetti Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
Muka express bialetti leaking
Easy!! Not making coffee or cappuccino, go to Starbucks less issues LOL
Apr 10, 2013 | Bialetti Mukka Express
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with...
I had the same problem and saw this solution in another bialetti mukka problem report, which made sense: "the safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
Jun 17, 2011 | Bialetti Mukka Express
I cannot unscrew the top of the Mukka Express machine from the bottom!
If the bottom is screwed too tight on the top, you could try to warm the with hot water and cool the bottom with cold. This could help to expand the top and make it easier to unscrew.
May 23, 2011 | Bialetti Mukka Express
I was looking for instructions for a Bialetti Mukka Express ;and also does this unit make espresso?
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
Mar 30, 2011 | Bialetti Mukka Express
Very rarley froths, is it worth buying a new valve (which I have just blown)?
To replace the valve and have it repaired may not be worth it. Just buy a new one. Repair cost could be expensive, since it does not function well (rarely froths).
We cannot be sure as to its usability.
Nov 08, 2009 | Bialetti Mukka Express
Bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Apr 12, 2009 | Bialetti Mukka Express
Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
Mar 08, 2009 | Bialetti Mukka Express
Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Jan 24, 2009 | Bialetti Mukka Express
Mukka valve broke
HAVE YOU TRIED SYDNEY?
Dec 07, 2008 | Bialetti Mukka Express
Bialetti Mukka Express Logo
557 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Bill Boyd
carlos parada
carlos parada
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
