Whenever i turn on my Gemini XP 800 Amp it burns out two fuses located in of Amp.It got four fuses inside,but two are always getting blown.
  • rharrison100 Apr 21, 2009
    yes, but how do i replace the transistors
    Top Expert:
  • Audio Player... Master
  • 79,847 Answers
Your output power transistors are blown, did you short the speaker wires?
Posted on Apr 21, 2009
Change a four prong cord to three prong cord, dryer heats, turns but does not dry, vents have been cleaned
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2ab3IwDXf
Jul 31, 2013 | Frigidaire FEQ332E Electric Dryer
Blown fuse on JBL amp
Are they inside. I ask because I just looked at pictures of the JBL GTO504 and there are only 2 fuses on the outside of the case. They are standard car type fuses with the current rating printed on them, looks like 20 Amp. You can just pull them out and replace them but you really need to find out why 1 has blown before replacing it.
Amp Pics Here.
May 11, 2012 | JBL GTO504 Car Amp
Gemini gvx 15, were is the fuse located, we can't find in nor inside or outside ?
It may NOT have a fuse. If too much power was sent or an amplifier drove DC to the speaker, the voice coil may have fried. The specs do NOT brag aboput protection, so it is likely either the speaker is blown or the internal wiring is broken. Open the unit and use an ophmmeter to tesst the speakers.
May 30, 2011 | Gemini Sound Products Gemini GVX-15 15"...
Gemini GA 2000 both 4 internal fuses keep blowing off.2 8amp and 2 12amp.Please what course this problem.
the power unit that feed the Amp is short this is why the fuse burn
its an hardware issue
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 14, 2010 | Gemini Sound Products P07 2-Channel...
2003 Suzuki VL 800 speedo cluster, signals, brake light won't work. Worked on the way to work this A.M. Checked the two fuses under seat. ?
Did you also check the system fuses? The fuse box is located behind the left side crankcase cover above the coolant reservior.
The 15 amp Signal fuse protects the coolant temperature light, the turn signal indicator light, the neutral indicator light, the oil pressure light, horn, brake/taillight, postition light and turn signal light. Basically, if this fuse is blown, your cluster will be inop.
Please let me know if this is helpful.
Jul 21, 2010 | 2002 Suzuki VL 800 Volusia
THE DRYER TURNS OK BUT DOESNT GET HOT AT ALL.CAN YOU HELP ALL FILTERS ARE CLEAN
if gas, check the following.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric, check the following.
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Whirlpool Dryers
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electric dryer, check the following
2. Heating element
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
My amp is turning on but!!!
you probably blew it up. Whenever you smell that smell it is almost always a capacitor in there that blew.
Jun 17, 2007 | Kenwood Excelon KAC-X521 Car Audio...
42 people viewed this question
 Grubhead
Grubhead
