my hero honda splendor plus 2011 emits white smoke while starting when the engine is cold. please give me an answer about this and what is the reason for this complaintmy hero honda splendor plus 2011 emits white smoke while starting when the engine is cold. please give me an answer about this and what is the reason for this complaint
AnonymousMar 12, 2014
my hero honda splendor plus 2011 emits white smoke while starting when the engine is cold. please give me a solution for thismy hero honda splendor plus 2011 emits white smoke while starting when the engine is cold. please give me a solution for this
You can't post conmments that contain an email address.
Technically Hero Honda Splendor Plus never reaches the speed of 95 kmph. As much as i can guess its top speed must be around 80-85kmph. Previous models having analog speedo used to do this, but i am not sure about the digital one as i have never checked it.
If you don't believe me then you can grab a copy of any auto magazine and check it.
first open the drain plug fitted on the bottom of gear box, when it is fully drained place the drain plug again now fill up new oil from top of gear box filling point
The Honda Splendor has a 4 stroke engine and can have worn valve seals or rings. If the engine smokes while riding it may be time for a top end re-build. You should complete a compression test to evaluate the condition of the piston and valves. If the compression is low ( under 120 psi ) it is time for a top end re-build.
Steve
