Question about Panasonic PT-52LCX66 Projection Television
Chage bulb tv is still dark
Hi i have a 52 inch rear projection tv panasonic i recently changed the bulb and my picture is still dark even with the brightness up anything else that may cause this problem
  • 65 Answers
The wrong or faulty lamp may cause darkness
Posted on Apr 22, 2009
Why will my Panasonic 52 inch rear projection will not turn on?
I had a 50 inch projection tv and when the bulb would go out there was always a popping sound. I went on ebay and found a new bulb at half the price the tv maker wanted. I would replace the bulb. If that is not the problem then you will just have a spare that will be needed at some point.
Apr 26, 2014 | Panasonic PT-52LCX66 Projection Television
Picture is dark and not clear the set is a49e
Hi, Try to change settings (contrast or brightness). If that does not help replace bulb in back of TV.
Good luck.
Jun 13, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic 51 inch rear projection--bought in 98 has dark picture
http://www.purelandsupply.com/Panasonic-Projector-Lamp.html or go here and call them @ https://www.interlight.biz/ they will answer any question and are half the price most of the time, please give me high rating
Apr 16, 2010 | Panasonic CT-27SL14 27" TV
I have installed a new lamp in my 52 inch panasonic hdtv and after just a minute the tv cuts off not sure why?
Hi
If the TV is working correctly during that minute then the shutdown circuit is sensing a component failure or mismatch. Did you plug the lamp, inverter, power supply back in correctly? What was the original symptom? Did the TV work OK for a minute and then after a minute go dark? If this were the case then the lamp may not have needed changing but rather a capacitor and/or IC overheating. Good luck
Apr 14, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
Feb 10, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have a 52 inch rca rear projection and has a red tint to it when dark image or picture
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't get full screen
What does "8 inches on each dark" mean? you can try the format button on the remote and see of this will fix it.
Mar 15, 2008 | Panasonic PT-65WX51 65" Rear Projection...
HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Jan 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-52LCX66 Projection Television Logo
752 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
