Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
BUNN Single Satellite commercial cof...
By todd_harris on Apr 21, 2009
Have an older 120-V BUNN Single Part # 23050.007. Recently it has started tripping the GFCI every day or more often than that.
I replaced the 20 amp GFCI outlet but it still happens. The GFCI tests properly with the test button. It resets properly on the reset button. Nothing else is using the outlet. After a half hour, a half day, or a day or so it trips again.
Any ideas of what part is shorting out?
Comments:
Apr 22, 2009
- yes it is 3-wire including ground, on a 20 amp GFCI outlet. The unit sits on a dry stainless steel counter top. The GFCI is dry, well clear of moisture. Thanks for helping sort it out.
Clarification Request
Posted by scspriggs on Apr 21, 2009
Does the coffee maker have a grounding (3-prong plug)? What type of surface does the coffe make sit on?
Is the GFCI exposed to any moisture?
Solution #1
posted on Apr 22, 2009
Somewhat Helpful)
scspriggs
Rank: Guru
Rating: 91%, 606 votes
Sounds like the coffee maker has a leak which is causing a ground fault inside the appliance. A very minor leak (just water vapor even) can cause this -- one that would never show itself by running out on the counter.
I would suggest taking it apart and looking for evidence of a leak.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
hi there, i have a problem with my Oscar coffe machine. Is not creating enough pressure at the... (More)
Answer
water leaks out of the bottom of Saeco Vienna. Removed the top and appears to be leaking out of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
