Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Stains on clothes
Dark stains on clothes but only on the corner areas of clothes like the tips of the collars on shirts, the corner of a table cloth etc. I don't know if the problem is from the washer or the dryer. Both are Whirlpool and about 10-15 years old. any ideas? Thanks,
Miriam
    Genius:
  • 1,198 Answers
Check the fit of the agitator to the bottom of the drum. After this many years, it may have warped up to make a gap. Run a rag around the joint to see if it marks.
Posted on May 07, 2009
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
What causes yellow underarm stains on my shirt?
The yellow stains that appear on your shirt are usually caused by many factors including sweat, soil, stress and antiperspirant ingredients. In case some of these factors come together, yellow stains appear on your clothes.
Feb 03, 2013 | Health & Beauty
Grease stains on dark clothing
this may due to softener,put spray and wash on stains and let it set all day,stop using softener use HE detergent and oxy clean powder wih soap in dispencer,also you may want to sanitize washer before you wash shirt also use the stain setting and extra rinse.thanks
Jul 29, 2010 | Kenmore Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
For some reason, my washer is now starting to leave rust color stains on my clothes. Not on all clothes but only on the corner areas of clothes like the tips of the collars on mens shirts or the small...
If you wash your clothes with warm or hot water, try using ONLY cold to see if the problem goes away. Sometimes older water heaters start to produce rusty-colored water as they age.
Jul 12, 2009 | Kenmore Washing Machines
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Clothes not clean after complete washing cycle
is it still heating the water? sounds like the element might be shot
Oct 12, 2008 | Zanussi IZ161S Front Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
169 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
