TV needs new power supply, won't turn on. Can I order the part from someplace? I can't afford the $250 + the TV repair shop will chargfe to replace this part. Thanks for any help you can give. Mary
TV doesn't turn on. It needs a new power supply. Is their a part I can order to fix this? The repair shop will charge $250 + to fix it and I can't afford it. Thanks, Mary McGreevy
  • marymac6 Apr 22, 2009
    I'm new to doing this on the net, as you can see, I included my name! Also am 66 y/o and not technically inclined.
    It is a Hyundai 27" LCD Color TV, Model # HTV-2700 (from the back of the TV). It is a little over a year since I bought it. I appreciate any help.
    Thanks for responding.
  • 8,617 Answers
If you can post the model number of your set I can post a link where you can get the board you need.
Posted on Apr 22, 2009
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Tv wil not turn on, either by remote or by Power button?
Hello douglastrame,
Welcome, and thank you for using FixYa!
If you are sure the TV is plugged in, then there can only be a few other remaining reasons why the TV won't turn on.
1. 5V low or high voltage power supplies are burned out.
2. Entire power supply is burned out.
Here is the part needed from eBay!
Power Supply Board
http://www.ebay.com/itm/VIZIO-VA26L-Power-Supply-715T3003-2-91324QA7-/370498439650?pt=LH_DefaultDomain_0&hash=item56436d89e2
Order it and install it yourself, if you believe you can. Or take the part and the TV to a local TV Repair Shop to have it installed for you.
Have a great day!
Sep 11, 2011 | Vizio VA26L 26 in. LCD HDTV
LG47LH30 lightning took out several appliances. TV won't turn on or any lights at all - acts as if it is not plugged in. Should I even try to fix? Are there interior fuses?
The lightning has fried at least the power source of the tv. Even if you you replace the source there are big chances that other components/boards have been also damaged.
There is nothing you can do to it, take it to a repair shop to have it diagnosed professionally.
Jul 03, 2011 | LG 47LH3000 LCD TV
We were watching the tv and it turned off and now it won't turn back on. we have never had any problems with it before.is it worth gettinh fixed.is there a rest button?
Tv now turn on have no power to the tv at all or the tv power LED light on the tv just blinks.Tries tv unplug,replug the tv back like about an hour,that the resetting tv back to the factory setting.The tv should working again now.If not the tv power supply board it is dead that the board where the power a/c cord plug into it,tv must be repair by replacing components parts or the tv whole power supply board.The tv shop should cost u like about half of the price of a new tv.
May 11, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I check my bestec atx-250-12e power supply with volt meter
It's hard to do with a volt meter. What you would be better off doing is either ordering a cheap power supply tester online, and test yourself with that, or take out the power supply and take it to your local pc repair shop and ask them to check it for you. There are 12V outputs, 5V outputs and 3.5V outputs, and any of them could be bad, so that is why I say using a voltmeter is harder than using an actual power supply tester.
Let me know if this solves your problem.
May 01, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Big screen tv. led turns on but no picture.Then tv turns off on its own. Need a ruff estimate on cost to fix.
Your TV has a power supply problem. The power supply board is not sending the correct voltage to the video board so the protection circuit shuts it down. The power board can be replaced or rebuilt. Most repair shops will replace it.
I have repaired many of these. Usually it involves new capacitors and fuses.
I would guess a shop is going to charge $150-$300 to fix this.
Dec 10, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Standby light is on but tv will not turn on
That sounds like a power supply issue. You can order a new power supply board for it and change it yourself, or have a shop repair the power supply. I would recommend having a shop repair that for you because there are a lot of things you can very easily damage, causing an even more expensive repair in the end.
Good luck.
Dec 01, 2009 | Samsung LN22A450 22 in. LCD HDTV
Power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
Jul 21, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips Magnavox 37" LCD Flat Screen 37MF331D \37
There are two capacitors in the internal power supply regulator board that have been the main culprit of this particular issue. You can identify the bads ones by the slight buldge at the top of the capacitors.
Feb 07, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Problem with power supply atx-300-12eb3
Faulty I should say, becaue you can repair it. Just replace the Buldgy capacitors. you'll need a soldering iron, soldering lead and a ****** to desolder the components terminals. Remember replace the caps with only the specific values indicated on them and also when replacing them see how you removed them is how you'll replace them and solder them back, if you not sure to do it yourself then provide the Capacitors and asked a friend who can do it for you. But if you think you can afford a new powersupply unit, thats fine.
Nov 12, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
