Question about Dryers
Start switch makes a buzzing sound when pressed; but won't stay engaged and doesn't turn the dryer on.
I just had someone in today to look at my dryer that when I turned "on" switch made a funny noise and the dryer would not turn. Found rear bearing dry and sticking, applied bottle of Hitemp lube, and it works just fine now on test (I think, not run a load yet). He initially thought perhaps the motor, but thank goodness was honest and tried the most reasonable solution.
Posted on Apr 21, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
Kenmore 65611 electric dryer makes buzzing sound when press start but doesn't start drying process
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Kenmore Dryers
My kenmore dryer push start button is not holding...it engages the unit but the button will not stay on! Any advise
if the start button is making a buzz sound and not kicking the dryer motor in then the motor is bad-mike
Mar 01, 2010 | Kenmore Dryers
The stop button will not stay and makes a buzzing
This sounds just like you have a bad door switch. You check it by taking the two wires off of it and taping them together. Then try the dryer. It should take off and run normally. If so, replace door switch. Good luck.
Oct 21, 2009 | Hoover HDC6 Electric Dryer
Buzzing noise, will not start
Your machine needs a new motor the start switch on the motor has worn out I have tried replacing the sart switch but the result is the same!
Jul 17, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
