Question about McCulloch Garden
Disassembly instructions for model # MCCI1635A McCulloch chainsaw
I need instructions on how to disassemble a model # MCCI1635A McCulloch chainsaw with a 16'' bar..I need to replace the gas tank and it looks like the flywheel needs to be removed before i can replace the gas tank..Any Help would be greatly appreciated..Thanks,Howard Sizemore Email h_size_99@yahoo.com
  • h_size_99 Apr 21, 2009
    All i need is detailed instructions on how to disassemble the chainsaw,so i can replace the gas tank..The user manual does not explain this at all,as i do have my user manual that came with the saw..Again,any help would be appreciated..h-size_99
  • h_size_99 Apr 23, 2009
    This is a pay site mostly,they sure as heck didn't help with my problem,except for reccommending a site where i could "buy" a service manual for $38.15..Thanks anyway..
gisvc
  • 40 Answers
SOURCE: I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay Item number: 150322102913 rtcurve.gif
good luck.
Posted on Mar 29, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
dontbother10
  • 2220 Answers
SOURCE: Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Posted on Feb 20, 2010
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
SOURCE: McCulloch pro/mac 10-10 chainsaw owners manual & gas to oil ratio?
I have an old McCULLOCH MAC 10-10 chainsaw that takes 40-1 gas. Take the metal air filter cover off, and look on the inside of it, it should tell you all the info you need like starting it, what kind of gas etc,etc
Posted on Aug 06, 2010
Macculloch 2214av fuel line routing
You'll need to refer to your users/service manual. It is best to take pictures before disassembly.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 21, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Oil it must be from the bar oil compartment is getting into the cylinder. The saw will start but lots of smoke. The bar doesn't seem to be getting enough oil. This is a PM 610
Good Luck Donald;
Your saw model is 600041; there are many prefixes and suffixes applicable to your saw, I defer to you determine the correct one. It has an impulse driven oil pump (all are similar). I suspect a portion of the oil pump has failed and engine vacuum is pulling oil into the crank case. You can find an IPL for your saw that will be may be helpful with oiler components and disassembly/reassembly. Your oil system appears to be quite complex.
Your IPL is here:
The IPL (exploded parts list) for your saw is the only detail for the oil system but it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 20, 2010 | McCulloch Garden
Needs new gas line
I would not attempt a fuel system repair without an IPL, but cannot provide you with one given the information you provided. I wish you good luck.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs
A typical fuel system and a suggestion or two follows:
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | McCulloch Garden
Where can i get a diagram to show me how to replace gas line and primer bulb on McCulloch 3214 chainsaw?
Afternoon Jimmy;
Let us begin with the IPL. The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch MTD (7 - 3214s to choose from)
Chainsaws 32cc-35cc
Use page 1 above to find a more detailed IPL here:
McCulloch IPLs
21 prefix example "600032" for a 07 suffix follows:
http://www.ordertree.com/modelinfo/MCC/21-600032-07-Mac-3214-IPL-211229-01/139.21-600032-07-Mac-3214-IPL-211229-01.1.59.1.html
The IPL in conjunction with this should provide ample guidance.
Lou
Mar 18, 2010 | McCulloch Garden
Need to replace the tension screw for the chain on a McCulloch chainsaw Where can find/ purchase this screw?
You provide no model number. There are over 300 different McCulloch models. If I give you a part number that does not fit your saw which of us is at fault?
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
This works for older Macs but MTD and Husqvarna saws often deviate from the explanation. It will give you a little guidance if you try to locate an IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
Lou
Mar 16, 2010 | Garden
I need to replace the power cord on the poulan es300 and the case does not come apart very easily
There is 1 other 300S model , do not it is significantly different.
http://www.ordertree.com/modelinfo/MCC/300S-14-07%2F93-to-05%2F96-IPL-211789/139.300S-14-07%2F93-to-05%2F96-IPL-211789.1.59.1.html
I recommend you open the attached IPL (300S-14) and use it as a disassembly/reassembly guide. I think the "General Assembly" print has the detail you need. If it were my project I might snap some photos as things progress just to refresh my memory when putting it all back together.
All saws can be found here (Alpha Numeric order; yours - right column about halfway down):
McCulloch IPLs
Good Luck. If I be of additional help please reply below. HTH
Lou
Feb 23, 2010 | Poulan ES350 16" Chain Saw
Hello Jeff;
McCulloch MTD
Lou
Feb 20, 2010 | McCulloch Garden
Need parts diagram and/or disassembly instructions
Here's a link to/for a free downloadable service manual (in pdf format), which contains disassembly information for the EPSON Stylus CX4100/CX4200/CX4700/CX4800/DX4200/DX4800/DX4850: http://www.opweb.de/model.php?id=4029. I've already downloaded it (today, 7/10/2012), and have been perusing the disassembly instructions which I also need and which appear to be quite explanatory.
Jul 14, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Garden Logo
614 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
