Question about Avaya Corded Phone avaparp18d
Ring on hour and half hour
Hi!
My phone used to ring once on the hour and half hour. It no longer does. How can I reinstate this feature?
On a dipslay phone press "Feature 59". It will display the release of the system. LEt me know that.
Posted on Aug 13, 2009
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the phone...is it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Mar 24, 2010 | Lucent Merlin Legend MLX-20L Phone
Lost the ring when phone is on DND. It use to
The phone should never ring when it is on DND.
The feature you are referring to is "Abberviated Ringing". If you are on a call and a second call comes in, it rings softly so not to bother you.
Abbreviated ringing is #305 in system programming.
Press Feature 00 (from extension 10 or 11)
Press left intercom, left intercom
press #305
enter the extension you are referring to
press 1 for active and 2 for not active.
Pres feature 00 to get out of programming.
Jan 20, 2010 | Avaya 700340193 Corded Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Call forwarding only rings once
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
Mar 09, 2009 | Avaya 5400 Series 5410 Phone
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
Mar 05, 2008 | Lucent PARTNER18 Corded Phone
Lengthen my ring time
hello you need to go into your settings then click on divert, it will say your settings are on divert:if unavailable thats why your phone call cuts off if you havent answerd it in a certain amount of time. So just turn divert off completely and your fone will ring longer
Jan 02, 2008 | Motorola Mobility RAZR V3
Avaya Corded Phone avaparp18d Logo
103 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
