HP LASERJET M1319
Hello, I have a HP laserjet M1319f MFP multifuntion printer and have problems to send faxes. When I call to the receiver, they pick up the phone and answer me. So, I ask for fax signal. When heard it, I press the sending buttom. Then, can´t ever send a fax. An error was showed on the unit (like, call error, no fax detected, etc.). But, if I call to a fax that was setted on automatic receiving, it works... I really appreciatte if you have an idea about what´s happening. Thank you Guillermo
Portenga_Mfg
SOURCE: hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Posted on Oct 06, 2008
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
SOURCE: HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Posted on Jul 24, 2009
Evildice
  • 222 Answers
SOURCE: HP Laserjet M1319f MFP - scanner not responding
check paper sensor, maybe he cant move
Posted on Sep 28, 2009
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
I have a Hp m1319f all in one printer/fax and we cannot send or recieve faxes at the moment. we have dsl hooked up to it and also when the number is dialed to the other fax machine, you can hear the other...
You state you are using DSL. Do you have a proper DSL filter on the line going to the fax machine. If not then the noise generated on the line by the DSL will cause fax send/receive issues.
Apr 04, 2011 | HP Laserjet M1319F Laser Multifunction...
HP LASer jet m1319f mfp errors no entries in fax log
check that it is connected to the phone line, if your phone line is working your fax system also work
Jan 07, 2010 | HP Laserjet M1319F Laser Multifunction...
Fax Printing is not Clear
You can change the default font of your printer from the settings panel at the front. Carefully go through the manual and you will be amazed how easy it is to effect such changes. However, if is attached to a computer, it will call the shot as default font of the system overrides that of the printer. Good luck
Apr 27, 2009 | HP Laserjet M1319F Laser Multifunction...
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Hp laserjet m1319 mfp series
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
185 people viewed this question
k24674
jasbo
jasbo
