Question about Dryers
My dryer is not heating up (it is a m460-g). I can't distinguish the thermal fuse. I think that is what is wrong with it. can you help me find it
    President:
  • 1,489 Answers
Trace the wiring -- you'll probably see several devices (thermal limit switches / tstats) which look kinda like small relays with two or three wires plugged into them. One of these is probably burned (or in some cases blown).
If you have a continuity meter, you can test each one of these for continuity between the terminals. They should all have electrical continuity when the dryer is not running. Of course, do this with the dryer unplugged.
Posted on Apr 21, 2009
How to check if Thermal Fuse or Heating element is blown
if the fuse was bad it just wouldn't work at all,it's non resetable,it will be hard to tell what's wrong now that it's working again but if the heat did go out and come back on there's a coil that runs through the heater,this breaks and then no heat but it could make a connection again,i ve found this one time out of 10 years or you could have a loose wire but it will be hard to tell until the heat shuts down again.also when was the last time you cleaned out the dryer,it should be cleaned out and blow out the vent line at least once a year.if the heat cuts out again and you need a hand let me know,also check the wires where the cord connects to the block on the back of dryer,if wires are loose this can happen.
Dec 27, 2012 | Dryers
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
The dryer is not heating. I don't think it is that old for the element to be out. Is that the only solution?
No, there are a few things that could be wrong. The element could be out, part of your breaker could have tripped but a common problem is the thermal fuse located on the element may have gone out. There are two fuses located on the element, a high limit and te thermal. The thermal fuse will be the smaller of the two. Its best to have a volt meter and unplug the wires from the fuse and check the fuse for continuity. If you dont have a meter you can tie the two wires together then plug the machine in and start it and see if it heats. Be careful not to let the wirestouch anything metal. (electrical tape works great!) The element and thermal fuse are located behind the back wall on the right if your standing behind it but in some models i the lower left front if the model has a kick plate t hat can be taken off. If your dryer's front is all one piece than its in th back.
Nov 04, 2010 | Whirlpool LEB6300 Electric Dryer
Thermal fuse blew...replaced it...got one load dried and new fuse blew...checked for clogged vents; are none. What else could be causing the thermal fuse to blow and so quickly as the new one did?
You need to change the t-stat, thermal fuse and high limit all at the same time...
read the electric no heat tip...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Dryers
My dryer works but has no heat whats could be wrong
hello there
:please go through each of these steps that i have provided belw
investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
07fcef1.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
f9921fb.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
17a0736.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat in dryer
Hello there Here are some ideas that may help you
- Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
hope this is very helpful for you
best regards Michael
Dec 23, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
My dryer does not turn on but the light still comes on
Remove the rear duct. Remove the back panel.The thermal fuse is 1 and 1/2 inches long and 1/2 inch wide. It is white in color and attached to the exhaust canister near the blower. Use a volt ohm meter to test continuity. No continuity replace the thermal fuse.
Do not bypass the fuse. It is a necessary safety device.
Mar 21, 2009 | Kenmore Dryers
Dryers Logo
250 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
