Question about Kenmore 76129 Air Conditioner
Unit will not turn on
My kenmore air conditioner model 76129 wont turn on any ideas??
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
If the display/control are not lighting/no power & unit will not turn on, the problem is likely the main power control board part number 6871a20271a. The board runs $40-50. However, if you are competent with a soldering iron, you can replace the integrated circuit chip [black rectangular 8 pin component marked TNY266PN] which I have found to be the cause of at least my problem.
The component is approx $1.50 [buy several, it WILL fail again] available@:
http://www.mouser.com/ProductDetail/Power-Integrations/TNY266PN/?qs=%252bk6%2F5FB6qrklhXU1XjM1kw%3D%3D
Hope this information is helpful to someone
Ray H.
Posted on Jun 02, 2015
  • 42 Answers
I have two of these units (actually it is my sister and brother in law's) but they come to me to fix stuff.
Last year they came to me with this unit not working. No indication of power on the display. I diagnosed it down to the PWB Assmebly, Main. I believe they are referring to it as a Power printed circuit board (part #6871A20271A). The new board worked for about 4 months and then quit in the same manner. Also, the second unit quit in the same manner also indicating the circuit board is bad.
I don't want to throw a board at it till I know why they are burning out. Also, want to try to diagnose the board to component level ($33.28/board last year). Let me know if this helps if you have the same symptoms?
You can replace the board but my experience says it will only last for a short time till we find the real cause (Sears must know this problem exist).
Posted on Jun 05, 2010
Kenmore window air conditioner model 580. Blows air but nott cool air. wont cool the room.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 02, 2011 | Kenmore 76129 Air Conditioner
Air conditioner was working great suddenly STOPPED working...cant turn it back on.
Hello
Is there a reset button located near the plug? If so reset it.
Check your circut breaker for the outlet its plugged into also.
If your using a remote to start this unit check that the battery is good in the remote,it may only work with a remote.
Jul 21, 2011 | Kenmore 76129 Air Conditioner
My air conditioner will not turn on. (See below for a more detailed description.) I recently bought a used Kenmore Room Air Conditioner Model 580. 76129. It worked well for about a month (running almost...
AC has a relay, it sounds like it failed on ya. If the unit was on all the time, was it that hot where you were or do you mean switched from AC to fan on all day? From what you said, it sounds like the unit burned its relay out for overheating, meaning thermostat may have originally failed keeping unit on until relay popped. Careful of fire hazard.
Jul 07, 2010 | Kenmore 76129 Air Conditioner
Kenmore air conditioner #25370156000 wont turn off
My educated guess is this would be a relay on the (or one of the) circuit boards. If you can access the internals parts try tapping on the boards which might allow the relay to release. A relay controls large amounts of current with small amounts of current (this means the controls can be small, working with small currents, also low voltages to control the relay on/off function.
Jun 25, 2009 | Kenmore 76129 Air Conditioner
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Kenmore 110 ac model 25370156000
sounds like 1 of 2 problems. first, check the condensor coil for dust, dirt, lint on the inside of the unit. this is the coil thats on the back of the unit that is outside. it can be sprayed out with a garden hose. make sure the unit is unplugged and let it drain for a hour or so. if the coil is not dirty, then the unit has developed a freon leak and needs to be serviced.
Jun 03, 2009 | Kenmore 76129 Air Conditioner
Kenmore the biggest 110 unit you can get, keeps shutting off
there is something wrong with your switches maybe. Or the thermostat problem occur.
Jun 01, 2009 | Kenmore 76129 Air Conditioner
Does the 76129 Kenmore Air Conditioner have a reset button
There is no reset button on this unit that I have located. I don't think cleaning the filter will help since you could just set the unit to run without the filter.
Aug 06, 2008 | Kenmore 76129 Air Conditioner
Kenmore 76129 Air Conditioner Logo
220 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
