Question about Pool & Spa
Part number discrepancy
I am replacing a Jandy pool light relay/dimmer module. The assembly number on the part is #6785. The assembly number on the parts offered on the internet is #6587. It looks like the same part. Is it?
    New Friend:
  • 77 Answers
The correct number is 6587. This should have a small pcboard attached. These dimmable relays tend to be short-lived if used regularly. I generally use a standard 3hp (6581) relay in its stead. They are a good bit cheaper and last much longer. The downside,of course, is that the light is either on or off.
Posted on Apr 22, 2009
RS4 aux3 and aux4 pulse relay instead of solid voltage.
You or some one else may have assigned the AUX 3,4 to "dimmer" in system settings. Check the setting and make sure it is not set for color lights as well.
Jul 16, 2016 | Jandy Aqualink Rs4 One Touch Control...
Why is my timed auxiliary continually going on and off for short periods of time?
Two things come to mind, (neither may be the cause). The first is referred to as "ghosting" where more than one program exists for the auxiliary and they over lap. This can cause erratic behavior from the system.
The other is that somehow your light dimmer has been activated. The light dimming relay is an option not included with the standard system. If it is activated and there is no dimming relay, this will also cause weird things to happen.
Try clearing all programs and then switch off electricity to the power center (outside unit) for a few minutes. Reprogram for the desired times. If the problem persists call a factory service rep at Jandy. At 22 years the board may need replacement.
May 23, 2013 | Pool & Spa
Control box makes clicking sound
either relay stuck or you have the wrong light fixtures entered or you have them set on a dimmer
Aug 26, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Aqualinks RS4 pool light button will not turn off. Has 6522 REV 1 on screen
bad light relay what ever aux it is replace it it is stuck on you can turn off breaker for light in temp fix
Oct 10, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy RS Light dimming relay replacement failure
Two things come to mind. Check the 'coil voltage rating' on the relay and make sure that's the voltage that you are powering the relay with.
Nest question is the 'relay contact rating'. The contacts have a current rating that needs to be checked. If the load that the relay feeds is pulling too mcuh amperage through the relay contacts, they will fail. The rating is on the relay, must check both of these things.
Sep 08, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
114 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
