Question about Karcher 2500 PSI Pressure Washer
I have a alto pressure washer i have problem with the trigger
I've had a alto washer pressure for two years now and obviously use it only once a year, so far i have had to replace the trigger twice as after a short use the trigger leaks,the water comes out of the trigger rather than the nozzle. I have tried fixing this myself but the trigger works only for a short time before the rpoblem starts again.Anyone out there that have the same problem.Any help on this would be very much appreciate or can anyone recommend a good quality pressure washer for domestic use, i use mine for cleaning my patio and drive.
thanks for your help
  • 33 Answers
GO TOO WAL MART AND SEE IF THEY HAVE A COMPARABLE TRIGGER AND NOZZLE ASSY. REPLACE THE THING WITH SOMETHING DIFFERENT. WHAT YOU HAVE IS JUNK AND WON'T NEVER WORK FOR LONG.
Posted on Apr 21, 2009
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
Fault Nilfisk Alto pressure washer
see the diagram and repair swtich:
May 14, 2012 | Vacuums
Husky pressure washer leaks by the trigger on the gun and I have replaced a broken o-ring and the new o-ring blows out of the groove. It is the same size o-ring as far as I can tell unless it could be...
Not sure about the o-ring problem but mine once leaked from the trigger, I found out I'd stored it without making sure it was empty of water, this had frozen & cracked something inside.
Sep 13, 2011 | Garden
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Aug 14, 2009 | Garden
Pressure washer intermittent turn on
sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have to remove cover to get to pressure switch, remove pressure switch piston clean regrease with silicon grease refit it m and all should be good.
Jul 29, 2009 | Garden
Pressure hose worn
ebay do plenty of replacement hose for the domestic and proffessional machines.
Jul 18, 2009 | Garden
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
229 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
