Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Emachines 390 blinking led but no image
I try po power my emachines 390 but there is no sign that will boot.Even if i pres the power buton(or hold)the pc do not sto i have to unplug it to stop it.I a m in quite a rush so can u reply to me a.s.a.p
thanks
    Scholar:
  • 172 Answers
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Chris
Posted on Apr 26, 2009
    Problem Solver:
  • 8 Answers
The problem could be many thing. Does it beep ? Can you see a white blinker on the upper left corner of the screen ? If you answer no for both questions, it coulb be the internal memory (ram) that is defect or even just dusty. But many other things could cause that. you can go to the link below and chat with a eMachine technicien.By the way when you try to turn off the computer, hold the power button until the computer shuts down.
http://www.emachines.com/support/product_support.html?
Posted on Apr 22, 2009
Webcamera no working acer emachines e727 for windows7 pc
Kindly perform the below steps:
- Remove the battery and Power adapter
- Press and hold the power button for 30-45 seconds (with battery and power still removed)
- Insert just the battery and attempt to boot the laptop.
After the laptop booted go to the eMachine/Gateway Support site and download the webcam driver and software.
http://www.driverscape.com/manufacturers/emachines/laptops-desktops/emachines-e727/3265
Mar 06, 2015 | Acer Aspire Computers & Internet
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
How do I do a full system recovery or an emachines et 1161-01
most pc maker has an aditional partition called recovery...you can use it since the bios boot
press f1 for bios setup
pres f10 for recovery
press f12 for boot order all you need to do is select recovery
May 17, 2011 | eMachines ET1161-03 PC Desktop
Emachines w3507 power
detarch all accessories or hardware connected to the system , then bring out the power pack itself out completely look for a soldering led to test the functionality of the power pack itself if it rotates the fan of its pack by looping the first hole to the third hole cable in the power pack connector that will head into the motherboard. therefore, check the mother board if there is any damage on it like some component if all this is false . then plug the power pack to the outlet and fix the connector of the power pack to the motherboard after detaching both cd drive , floopy disk drive leaving the hard disk and the memory . then change the memory card and press on the system there should be a solution from all this . the problem should be from the Memory not to be able to start up the system but go through those process i have given you before concluding it was the memory ok....
kindly rate this solution......
May 05, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Im using a emachines T3646 computer,only pwrled and 1syst fan wrk
Yes. Got RAM? The heatsink fan? How about a video card, and all the 12V (4 to 6 pin) connectors? All plugged in suitably?
May 02, 2010 | eMachines T3646 Refurbished AMD Desktop...
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
Hi i need drivers for emachines 390 plz help me thanks
I could not find the 390 model specifically, it seems there is possibly more to the model information that is needed. However, you can go to the emachines website and dowload drivers if you have the full model information and internet access.
Hope this helps.
Dec 31, 2008 | E-Machines eMachines Desktop PC
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
Wont boot up
try to change your RAM,if same also
try to change your graphic card if u use it...
happy trying..
good luck..
Apr 17, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
303 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
