Question about Samsung TV Remote Control
Cable remote will not change channels
I cannot change the channels using my cable remote control
  • Anonymous May 07, 2009
    What I want to know is when I try to PUT the remote in cable mode, it does not respond and I am going nuts with this right now.
Read the cable manual and when that dosen't work then come on here ask the world and get a bad solution from someone (like so) and then write your own bad solution and repeat when ever you need help my real solution is don't come to fixya again because any one who gets on here never really knows the answer to questions like that just call the cable guy OK don't come on here!!!!!
Posted on Jun 30, 2014
    Champion:
  • 226 Answers
You do not have the remote in cable mode.
Posted on Apr 28, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Posted on Oct 12, 2008
Remote frequency for my cable receiver seems to be the same as the remote frequency for my TV
Hi Thor!
You have to select "Cable" on the universal remote on the cable to change the channels on the cable box.
And press "TV" on that remote to change or access TV Functions.
Or use only the TV remote only to change Inputs on the TV.
Good Luck,
JP
Oct 25, 2015 | Televison & Video
My UR5U-8700L remote doesn't change the channels, but I got it to turn the TV off and on. How do I program it to change channels from the cable box?
1) Press the “Cable” button at the top of the remote to put it into Cable Box control mode.
2) Press and hold the “Setup” button until the “Cable” button blinks twice.
3) Type in the code 994. The “Cable” button will blink twice
Mar 06, 2010 | Televison & Video
Can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
May 21, 2009 | Samsung TV Remote Control
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Samsung TV Remote Control Logo
497 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
