Any way to quiet down a nosiey hard drive WITH OUT REPLACING IT
  • 31 Answers
Well in that case there might be few reasons as either the HD mounting screws maybe too tight, loosen them and retighten to snug fit. or place a small rubber washer between screw(s) and metal flange. or relocate HD to another available space if possibel. You didn't mention it, but clean out the system case as well to better cool the system. These are areas to look into, but it could be something else, especially a HD failure coming, so take precaution and safe-guard your data(back it up) just in case. Also, understand it maybe possible not the HD is noisy but a fan, so check into those as well.
hope you find it usefull.
your feedback is appreciated. Askari:)
Posted on Apr 21, 2009
  • 89 Answers
No sorry.
please rate my help to you.
THANK YOU.!
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
How fix Loud g4 Hard Drives
Not sure what you mean by loud Hard Drives. Hard drives are so quiet you can barely hear them. If they are loud the only cure is replacement. However, I have never heard a hard drive that I would consider 'loud' in all my years in computing./ As you show a mirror fronted mac in your question - I think you may mean loud 'Fans'. This mac was notorious for its loud fans. They can be replaced, but I seem to remember a firmware fix from Apple to slow them down - or it may have been a 3rd party utility.
Apr 01, 2012 | Apple Power Mac G4 Desktop
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
A/C compressor nosiey - how big is this to repair
not that hard just take the car truck and have the freeon removed safely once that is done you can go at it.remember have the freeon removed and diconect the positive cable
Sep 02, 2010 | 1995 Oldsmobile Aurora
Wont boot. Black screen Hard drive light flashes 3 times then every thing goes quiet.
Does it completely shut-off on it's own? If so, then you're likely needing some component replaced. First check the RAM & and then the hard drive. If neither of these is causing the problem, then you're looking at some more serious work needing to be done on your laptop. Unfortunately, the only way to check your RAM is if you have some extra memory sticks to swap into your computer, or another laptop that is compatible with your laptop's RAM to try in it. The same goes for checking the hard drive too. Does your hard drive make alot of noise? If so, then that will probably be the cause. If you end up replacing your hard drive on your own, then be sure to order the correct hard drive. The size of the hard drive isn't really a big deal, though I recommend replacing it with something that is 160 GB or larger, since your original one was probably 160 GB. The interface for it will have to be SATA (Serial ATA), not IDE (PATA).
Apr 10, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
My sony valo computer has a very loud hard drive
There are multiple ways you can make your computer quieter. You could put the drive in a quiet case like these. Or you could replace the drive with one of these quiet hard drives.
Mar 31, 2009 | Sony Computers & Internet
Power steering
Make sure the fluid level is OK, if reservoir MT ad, with out the cap till air comes out and fluid gets in to system, turn the steering right to left wile You add fluid with cap off, till fluid is not longer going down and reservoir inside gets quiet, when fluid level is OK, put cap back and try it, if system did not recovered normality and loud noise comes from the pump, pump needs replacing, if steering is steel hard, no noise comes from pump, look a steering box or steering arms, if truck has Rakenpinon, look for broken boots, pit man arm
Jan 22, 2009 | 2001 Dodge Ram 2500 Truck
I have a black screen. There is power I can hear and see the lights. I was replacing some memory when it began.
Is the hard drive firing up?
You may well have power and lights but a blown system board.
if its running then you should be able to hear the hard drive working as it loads windows.If all is quiet then suspect a board down - maybe static done it as you worked on the memory install - it happens!
Dec 21, 2008 | Computers & Internet
Noisy motor on Dyson Vacuum Cleaner and how long should a motor last Roy
A motor can last a long time or a short time, there is no way to predict how long one will last. Most times it is dust has gotten into the motor bearings and they get nosiey. Replacing the motor is the only cure.
Apr 24, 2008 | Vacuums
Emachine T3508 Loud Loud Loud
The only sure way to quiet it down is to replace the hard drives with newer ones, that you have selected based on their noise rating, AND to replace all the fans in the machine with fans that you have selected based on their noise rating. I did this for my self-built machine last year and never regretted spending the money on new drives and new fans. It's SO much quieter! ;)
Aug 04, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
