Emachines laptop bios problems
I cant get my emachines W4605 laptops bios to recognize any drives(hdd, dvdrom) and when i go into the bios the HDD firmware version is just a blur of dots. I have no idea what is wrong with the computer, it got it at an auction. it has a phoenix bios, version 67.08.00
  • mike_micro Apr 23, 2009
    I checked the connections, and they all seem to be fine. and under the boot uptions there is one called usb key and another called usb hdd, and usb cdrom, but none of them do anything or show anything with the usb stick plugged in.
  • Barry Parks May 11, 2010
    Have you checked the connections to the drives? There should be a data cable and a power connection. If it is an IDE drive, the cable will be wide and flat with a red stripe down one side. The Red stripe marks pin 1 and the cable is attached so that the red stripe is next to the power connection. Also check to see that the other end of the data cables are firmly connected to the motherboard.
    If the BIOS isnew enough to detect USB devices, you can try plugging in a memory stick to see if that is detected.
    Test that and let me know and I'll try to help more.
    ~ Spoem
D525 hdd password forgotten---frozen
The hdd password is stored in the firmware of the hdd, not in the bios. There is only two options available.
1/ type the password.
2/ purchase a new hdd as it is totally unformattable in that condition.
Jul 22, 2014 | Acer eMachines 520-2890 Notebook
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
My laptop will not boot up when i switch it on it says to insert my windows installation disc and restart my computer but i dont have that disc what will i do.
Hi
Awailson
This problem can pop up only if the OS in your HDD is damaged. Or if your HDD is bad (Physically) hence i can suggest you to boot from the CD provided by the company which came along with the laptop to boot. If you do not have any of it you can try to boot from any other CD to just check if the HDD has a problem really. If the HDD is accessed by the OS then no problem. But if it is not recognizing the HDD then you need to replace it.
Jul 26, 2011 | eMachines E620-5885 Notebook
Format WD laptop hard drive in Emachine laptop
Normally when u restore, formatting is being done at a certain step. Therefore no need to worry as the OS is included in the recovery. However if it's exactly how u r stating, therefore buy an external 2.5" HDD casing,insert ur HDD in it, plug it to the USB of any computer or laptop & get it formatted.
Feb 07, 2010 | E-Machines eMachines Desktop PC
Emachines model MS2257 HDD password
Can you get into it at all. If you can't, try to reset to the factory presets. You can do this with:
  • A restore CD
  • A XP/Vista disk and choose to re-format and re-install it again (probably your best bet)
  • *If you can get in as a guest* Re-install from hidden Restore drive. (Usually by pressing ALT - F10) You
Sep 04, 2009 | Computers & Internet
Dvd rw not detected in Bios and not working V5535 Fujitsu
you could try removing the cmos battery in the bottom of the laptop look in manual to see how or you could install using usb external dvdrom set bios to boot from usb dvdrom first
Jul 30, 2009 | Computers & Internet
Drivers for w460 emachines laptop
try getting it from google if you cant,reach me on my email-opaluwavictor@ymail.com.
Jul 02, 2009 | E-Machines W4605 Notebook
PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: exiting Broadcom PXE ROM. Operating system not found. how 2 solve or repair? help me...
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 14, 2009 | E-Machines eMachines Desktop PC
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
