Question about Garden
Cub cadet 3000 hydrostatic tractor dont move
Cub cadet hydrostatic trans tractor dont move
boscia
  • 163 Answers
SOURCE: hydrostat pump leak,cub cadet garden tractor
try tightening the connections. if that doesnt work you can disconnect and wrap the threads with teflon tape but this requires draining the hydro system
Posted on Nov 30, 2008
defadad
  • 351 Answers
SOURCE: hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
Posted on May 23, 2009
mickey813
  • 472 Answers
SOURCE: Cub Cadet (105, I believe) hydrostatic transmission problem
you may want to pull the check valves out and make sure the ball arnt stuck if thay are it will do that just lube theme up with some wd40
Posted on Apr 20, 2010
  • 146 Answers
SOURCE: I have a cub cadet mower and it has the hydrostat
There are two belts - the main drive belt from the engine to the hydrostatic transmission, and the mower belt that runs from the engine to the mower deck. Sounds like the main drive belt broke or came off. It's not an easy job to replace because it's up against the chassis underneath, and you usually have to remove and replace some parts to get at it. Take a look under there, see if the belt's gone, and decide if you want to tackle it or have a shop do it.
Posted on Jun 12, 2010
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
The transmission is slipping on my cub cadet lt1046 hydrostatic lawnmower. It will move in reverse but barely creep along in forward
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
May 30, 2011 | Garden
I have a cub cadet mower and it has the hydrostat trans drive and I hit a tree root in the yard and the tractor quit moving. The mower deck still runs so is there a belt broken or what could be wrong?
Jun 12, 2010 | Cub Cadet Garden
Apr 20, 2010 | Garden
89 cub cadet, 1420, hydrostatics trans, moves very slowly forwards & backward
check the drive belt for ware could be slipping or might need to add oil to rearend
Sep 21, 2009 | Garden
I have a cub cadet 1250 hydrostat drive. It just
No your trans is getting too hot clean the dirt and grass and fluid off of it and make sure the fan on top has all its blade and is turning with the belt.
Aug 22, 2009 | Garden
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
