Question about Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021)
Help!!! My Aero theme gone
Hey i was wondering if someone could help me. I was trying to get new themes for my windows vista but i apparently needed to download Vista Visual Master to do that, and in the process i somehow edited my Aero theme cause it's not working anymore it's there in my windows/resourses/themes but it's not there when i go to change my appearences i've only got windows classic and windows standard and another 3, but none of them are the windows Aero. I have a hp pavillion entertainment pc and i think it's running on windows vista home premium, but i'm not entirely sure.
  • 1jkwaasit1 Apr 23, 2009
    Hey Yeah everything's ok now. I went into Computer/Windows/Resources/Themes and changed it from there. Now it's all fine. =)
  • Mikael Guggenheim
    Mikael Guggenheim May 11, 2010
    Have you turned of system restore point? If not I suggest you load a restore point from before you changed the systemfiles.
    President:
  • Microsoft Master
  • 1,996 Answers
Glad to hear it was settled.
In future, this link might prove helpful...click here
Posted on May 15, 2009
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
Hey guys. Pretty silly question regarding Windows Aero
There are some add-on packs out there. Some require 3rd party software. Some are themes.
You may have to sacrifice performance for looks. Something to consider.
Oct 02, 2012 | Microsoft Windows XP Home Edition for PC
I have installed Windows Vista Ultimate on my PC. Now the Aero theme is not working and the same is missing. Please help.
Hey, i've had the same problem. Did you try patching the aero theme? Cos i did the same and it corrupted! One thing you can try now is that you can copy this theme from any of your friends' PC which is running Vista Ultimate and copy it in yours'. You shd paste the file under "C:\Windows\Resources\Themes" (shd have Admin rights to do this). Then apply the theme as usual.
But if the above doesn't work and you are desperate in need of the Aero theme, then no other way other that re-installing the OS.
Hope this help. If so, rate me.. thanks - billa
Sep 05, 2009 | Microsoft Windows Vista Ultimate Edition
Messed up vista theme
probably you have missed the uxtheme.dll file, press windows key + r
type in sfc /scanonce and insert origninal vista dvd , after restoration reboot and you will have your shiny theme back
Aug 26, 2009 | Microsoft Windows? Vista Home Basic...
How i can get window vista look in windows xp
http://rapidshare.com/files/52953075/Best_Vista_Theme_For_XP.rar
Click the link above, then click the free user button. Follow the onscreen prompts to download and install the program and it will install the Vista mods to your XP system.
Hope this helps FixYa,
Chris
Jun 06, 2009 | Microsoft Windows Vista Ultimate Edition
Bad resolution and aero glass theme not working
Sounds like you have Intel Ingregrated Video with less than 1 GB system ram.
The answer is the system does not have the hardware to Run Vist Aero Mode, and apparently has minimal ability to run Vista at all.
You may be able to get a better video driver than the default at Support.dell.com.
More than likely, you are looking at putting Windows XP back on the system
Apr 12, 2009 | Computers & Internet
Need Vista Basic theme not Aero
Right click your desktop and choose personalization. In the drop down menu select Vista Basic and apply.
Mar 30, 2009 | Microsoft Windows? Vista Home Premium...
MY THEMES DOESNT COME BACK TO NORMAL
First, make sure the video card drivers are up to date, and that the Video card meets the minimum requirement for AERO
here is the Microsoft AERO troubleshooting page
Feb 06, 2009 | Microsoft Windows Vista Ultimate Edition
Hello hw to get the defualt aero theme in vista
This page should have all the answers:
http://windowshelp.microsoft.com/Windows/en-US/Help/c33fe91a-9e6f-41f4-ae82-3ed2d5fa2fbf1033.mspx
Jul 16, 2008 | Microsoft Windows Vista Ultimate Edition
I can't apply vista themes which i have download from internat as i have window vista home premium
The error you are getting says that the theme can not be loaded because theme service is not running, so to start the themes service press WIN+R on your keyboard, type "services.msc" in the run box (without commas) and from the list that opens, find the theme service and start/enable it.
Oct 19, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
270 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
