Question about Estate TS25AFXK Side by Side Refrigerator
Food and drinks freezing in my refrigerator. How do I adjust?
My food and drinks are freezing on the refrigerator side of my side my side model ts25af estate refrigerator.
  • Estate Master
  • 4,654 Answers
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 21, 2009
The refridgerator compartment is freezing all the food
What is the complete model number list in the refrigerator section?
Oct 11, 2013 | Samsung RFG299AARS Stainless Steel (285 cu...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
When The Temperature Setting Is On 1 The Food In The Freezer Dosent Stay Completely Frozen But When i move it up to setting 2 it freezes things in the fridge...and theres water leaking out the back
Do you just adjust the fresh food side or do you adjust the freezer setting too? Post the model # . does the unit have knobs or buttons for setting temp? Does food freeze in one particular part of the fresh food side or evenly throughout?
Apr 15, 2011 | Refrigerators
The fridge section of the appliance is not automatically defrosting the fridge is on the lowest setting but still manages to freeze food and drinks solid
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 14, 2011 | Refrigerators
My miele fride keep freezing at the back and all the food and drink is freezingnup,help
heatman101
Jan 01, 2011 | Refrigerators
REFRIGERATOR SIDE TO COLD,FOOD AND DRINKS GET FROZEN
heatman101
Dec 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge won't get to 37 degrees, Fridge is freezing my food.
if freezing food it must be 32 deg or lower . if you need to get fresh food side warmer the adjust tempt . if it will not adjust then the control must be frozen in the open pos and will not close . so replace the cold control . or if more info is needed then i need model # to help mm .. hope this helps .
Sep 22, 2010 | GE Refrigerators
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Estate TS25AFXK Side by Side Refrigerator Logo
315 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steven Clarke
Steven Clarke
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
