Question about Brother ML-300 Typewriter
The letters are not showing up on the paper - Brother ML-300 Typewriter
    Problem Solver:
  • 19 Answers
Make sure your printwheel is installed with the letter indentations facing the paper, and make sure the ribbon is placed between the printwheel and the paper. Also, check your ribbon to make sure it has not dried out.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Posted on Apr 21, 2009
Canon imageRUNNER 2200 paper tray 1 shows empty when it is full. Using letter paper with portrait orientation. Dial is set correctly for letter (LTR). (tray 2 is letter in landscape orientation. Dial is...
Please check that there isn't any paper jam behind the tray in the machine, this will block the connection from the tray to machine and prevent the paper lift mechanism from raising up into proper position. Hope this helps.
Oct 14, 2011 | Canon imageRUNNER 2200
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
CAN'T GET ALPHABET LETTER TO APPEAR FOR STATION ID.
Letters are on the soft pad to the left of the number keys. Very tiny, so look close. You can also lift up the mylar sheet and remove the paper sheet.
Mar 04, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
On/Off button red...letter
"P" flashing usually means No Paper or Load Paper. Check the Sensor. Make sure paper Sensor is not stuck in the Up position.
Sep 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Paper Miss match
Please select printers and see the properties and there will be a d efault paper size which may be lette A3 etc selecrt it to your desired paper size in the settings Ok.
Mar 05, 2008 | Samsung CLX 3160fn All-In-One Printer
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Brother ML-300 Typewriter Logo
82 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
