Question about Dynabrade Air Tools & Compressors
I have 5" Dynabrade Orbital sander that needs a new sanding pad and could probably use a going over at the same time. Who does this work? Cost
  • 226 Answers
You can get new pads at the automotive paint stores in your area. They are not expensive. Most of these wholesalers have a service department that can r&r yours. Hope this helps you, Rick
Posted on Apr 26, 2009
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Can i use my dynabrade sander to car polishar
I would not recommend it for that purpose. A polisher has a much SLOWER RPM than a sander and you would probably cause paint damage from burning, secondly the polishing pad might not be rated for this higher RPM.
Feb 17, 2012 | Dynabrade Tools & Hardware - Others
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
I can't get the sandpaper to stay on the pad.
It sounds like you need to replace the backing pad on the sander. Over time the velcro (hook & Loop) on the backing pad will loose its stick. A Bosch service cneter can supply you with a new one, just let them know which model you have. If its an adhesive back sanding pad the same thing applys just get a new one. Hope this helps
Apr 11, 2009 | Bosch Power Tools Sanders Orbital Sanders
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Air Tools & Compressors Logo
187 people viewed this question
Top Dynabrade Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dynabrade Air Tool and Compressor Expert? Answer questions, earn points and help others
