My VGA 9400GT x5 tech ddr2 1024MB(MADE IN TAIWAN) have a problem: somtimes my screen put in standby state,and still computer working. so i tried it on another computer and found that it has no problems,so i think the problem is in my VGA, can help me? note:when i turn my computer on it give 8 or 9 beeps!?
  • Kenny Wilson May 11, 2010
    check to see if the card is properly seated.
  • 37 Answers
The beeping is your motherboard telling you that theres a problem with the card. it may work in your friends pc, but they probably have a different motherboard. what is the motherboard that you're using? make sure that they are compatible.
Posted on Jul 21, 2009
  • philip mckean Jul 21, 2009
    you could also make sure that you have the very latest bios for your motherboard. a simple update could fix the problem.
My Acer M5640 desktop lately when start up, after the beep nothing appear on the screen, hv to turn off the power and try again, somtimes it will be ok, what's the problem?
As the computer gives the beep it shows it is working, it has pass the Power On Self Test.
Your problem is a loose connection, either at the Graphics card slot or on the monitor VGA ports.
Check the VGA ports at both the Graphics card and at the monitor. Also clean the RAM modules of dust and reinstall.
Take care!
damnor01
Apr 17, 2011 | Acer Aspire m5640 PC Desktop
Black Screen after installing new NVidia 9400GT
Put the old card back in, remove the old drivers and restart it in VGA mode.
You don't say what operating system you use, but XP & Vista you should be able to hit F8 before the windows splash screen to select VGA mode or Safe Mode.
Once you do that you should be able to put the new card in and start it in standard VGA mode then load the new drivers.
May 25, 2010 | SPARKLE Computer Sparkle GeForce 8500 GT /...
How to connect hdmi audio cable from video card Geforce 9400gt to mother board foxconn G33M02
Your Geforce 9400GT doesn't have a HDMI outlet. It only has DVI, D-sub and S video. So I'm not sure what you're asking.
Apr 18, 2010 | Dell Vostro 200 Desktop Computer
Is p5sd2-vm graphics integrated mbd supports nvdia gForce 9400 gt.
Yes it is compatible with Gforce 9400GT
the motherboard has 1 PCI Express x16 , 1 PCI Express x1 , and it is compatible...
Hope this helps
Apr 02, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
Mar 24, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Zoom X5 broken after firmware update
same happened to me, but i definitively put the new firmware. I send the modem back to support and got a new one.
maybe you can try to reset the modem in the very short, 2 to 4 seconds, startup procedure.
i had to do that, because i messed with the dhcp address table.
Dec 19, 2008 | Zoom X5 5654 DSL Modem (DH5654)
Code for sky remote control
tech guy from ebuyer said no code available but sky remote will work ok but volume and tele on- off facilities will not so use remote which came with television to do this so says he.
Apr 17, 2008 | Hannspree (K206-10U1-005) Television
Monitor lives its own life ;) Turnes off and on in random moments
It sounds like there's a problem in the power supply or inverter section and it's just teetering on the edge of failure. The disruption of the signal is apparently just enough to kick it over the cliff until it's reset. Sooner or later, it'll need some help, like connections, capacitors, output transistors, capacitors, transformers. Those are the most common failures in these. I think you'll see it get worse
Jan 25, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
