Question about Dishwashers
The bottom of my dishwasher is not draining properly. Have cleaned it out completely. What should I do next?
  • 10,865 Answers
You most likely have a partial blockage in the pump that sends water into the drain hose. Remove the lower front panel so you can work on the dishwasher. Remove the hose clamp and pull the drain hose off the pump. remove the pump and look into it to remove whatever is blocking it.
Posted on Apr 21, 2009
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
After dishwasher run through it's cycle, the water does not drain properly and remains in bottom of the dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 10, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher has water on the bottom after the cycle is completed. May not be draining properly.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Jan 24, 2011 | KitchenAid Dishwashers
My dishwasher is not draining off the water properly. It has flooded the kitchen once already. I can here the pump running, but it is a bit noisy. The bottom of the dishwasher is still full of water after...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Frigidaire Professional Series 24 in....
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Why does my dishwasher not totally drain out? there is always about a half inch of water at the bottom after the complete cycle.
There is a float located inside the dishwasher that lets the washers control board know if the water is completely drained. It is a 3 to 4 inch diameter disk shaped float. It may have a dome cover over it the you will have to remove.
Make sure there is nothing trapped under the float and holding it up. You should be able to move the float up and down with you fingers.
Next, do you have an "anti-siphon" valve on the drain hose or siphon loop in the hose. Make sure both are functioning properly. Make sure the drain hose is clean and clear. If the hose is plugged or partially plugged it can cause the water to backup in the washer.
Check it out and let me know.
Regards,
Aug 25, 2009 | Whirlpool Dishwashers
Not cleaning properly
It sounds like the dishwasher is not completely draining... this leaves particulates floating in the water and is redispersed during the next cycle.
If it were me, I'd consider taking apart the bottom rotating sprayer and the plastics that cover the draining impeller (or pump). My guess is that contains a large amount of debris which should be cleaned out. If that isn't the case, check the pump itself. Something might be in there preventing it from working, or may have damaged it in a previous cycle (ie: chicken bone). Any screens or traps should be completely clean. If you use powdered detergent, there might be a buildup of solidified detergent preventing things from working properly and will need to be cleaned. If you use powdered detergent, consider switching to liquid as it tends not to solidify.
Let me know how it goes. Please rate accordingly.
May 08, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
Owen Barnes
