Question about Olympus FE-190 Digital Camera
Lines through photos
Before now i never had a problem with my camera, and i can't think what i've done to cause it damage but... i turned it on today to take photos and the screen is clear and fine when about to take the photo. but when i press the button to take the photo it becomes all unfocused and has horizontal lines through it. these turn up also when reviewing photos and when i download the photos to the computer. this does not happen however with the movie setting. please help!
  • 2 more comments
  • geeorrrge Oct 14, 2007
    thanks, took it to a camera repair place and they are getting it fixed and its all under warrenty which is great.
    haven't got it back yet but they said they think it was a lens problem and are waiting on a part.
    will get the full report back with the camera.
    thanks again :]
  • Anonymous Nov 22, 2007
    I have the same problem. my camera is an FE-180 rather than an FE-190.
    Dan
  • Anonymous Mar 09, 2008
    same problem! Can't take pictures without white lines thru them.
  • aalyssa Mar 20, 2008
    Same problem! How long does the warranty last, do you know?
    Genius:
  • 2,985 Answers
This is a mainboard processor problem It is a maker repair or replacement situation depending upon the age of the camera - contact Olympus support Be prepared to buy a new camera however if they want money for a repair.
Posted on Sep 22, 2007
SOURCE:
Picasa no longer recognizing Nikon Coolpix L5
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
Jan 31, 2013 | Nikon COOLPIX L5 Digital Camera
When I try to take a picture, the screen is all white.
there might be two issues here (1) your phone 's operating software is corrupted with virus or viruses if there are some unusual applications which are running and difficult to uninstall try to root your phone and uninstall them you can use king root to do this , (2) your phone 's hardware connection from the camera to the motherboard is disturbed try to open the phone and clean it, your can also look for dry joins , if you have a hot air station you can blow the motherboard ,take not of the temperature. try to view photos from another memory card
Feb 20, 2018 | Canon PowerShot SD1400 IS IXUS 130...
I purchased a memory on sunday - took pictures and downloaded to computer but did not delete from camera. today i took more pictures and reviewed them - all was o.k. before downloading onto computer, i...
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones. Now after you've recovered your photos, consider formatting the card in the camera to prevent this from happening again.
Jul 27, 2011 | PNY 4GB Secure Digital High Capacity...
Lens error
I've got the answers...
Problem: Lens error.
Symptom: Lens will not extend upon power up.
Cause: Lens is impeded while trying to extend.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the main drive gears to be damaged.
Solution: Replace the main drive gear assembly. This should only be done by a qualified tech.
If you've experienced this you know exactly what I mean. This should clear up any notion that the "Lens Gods" have cursed you. Although this may have appeared to be a mystery, it's always caused by something!
Symptom: Lens extends, makes a few buzzing noises and retracts, resulting in "lens error" message.
Cause: This is caused by damage to the focus lens often by impact, or sand in the mechanism.
Solution:The focus lens gears either need to be replaced or the assembly completely rebuilt. Again, this should be done by a qualified tech. It's a very delicate process.
Problem: Aperture unit failure
Symptom: images appear to be washed out, over exposed and often have horizontal lines through them.
Cause:The aperture unit is either stuck, damaged or not receiving the proper electrical signal to activate. The result is that the aperture remains open after the picture is taken and CCD is over exposed.
Solution:Completely rebuild the aperture unit, which requires complete lens dis-assembly and rebuild. Again, this should be done by a qualified tech. It's a VERY delicate process.
Additional details in THIS LINK.
Hope this helps.
Apr 27, 2011 | Casio Exilim EXZ75 Digital Camera
Cuando tiro una foto de dia la imagen sale muy blanca, no se define parece un negativo como situviese demasiado brillo, si tiro la foto de noche se ve mejor aunque con rayas horizontales casi...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 14, 2011 | Samsung S860 Digital Camera
I have a DSC H10 camera. Today I put it in a plastic with a water bottle that wasn't close tightly. It got wet and now I've taken out out the battery and the memory card. I let the water drain out, I wiped...
Turning it on before it completely dries out usually causes a short circuit. It can take up to a week with your camera buried in a bowl of dry rice to dry out. However, since you turned it on, it may be too late but try it anyway.
Jan 29, 2010 | Cameras
Ummm, recently my Photo Loader does not work, I
Yes try to uninstall photo loader and the adobe is effecting because similar software. Good luck
Oct 19, 2009 | Casio Exilim EX-Z100 Digital Camera
The image sensor has failed, you need to send it in for service or get another camera. Unitedcamera.com
Apr 14, 2017 | Cameras
Fuji a 700
I THINK THE MERMORY CARD IS DAMAGE MAYBE BY TRANFERRING PHOTOS AND NOT DISCONECTING CAMERA SAFELY FROM COMPUTER
Nov 03, 2007 | Fuji FinePix A700 Digital Camera
Blurry/strippy photos
Nothing seems to help. My camera just started doing this. I'm taking it back...
Aug 13, 2007 | Nikon COOLPIX P4 Digital Camera
Olympus FE-190 Digital Camera Logo
288 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
